Hi everyone,
I need some help finding out what is wrong with my scirocco 1.4 tsi from 2010.
I am having some trouble with my battery and i think it is due to the front headlights.
I have automatic light on/off switch and when i put it to off, the lights still stay on.when i have them on aut.and i am driving during a sunny day they are always on. .
Anyone who knows what it Could be?
thank you
Dan
Agreed with above - I assume you are referring to the DRL's (day time running lights) - they are always on during the day.
They will not be the cause of your battery problems - the probable cause of your battery dying is it's age if you are on the original factory battery.
I have found that the OEM VW batteries rarely last past 4-5 years....after 5 years they're toast and go flat easily.
Was the same in my Mk5 golf TDI 2.0 - that battery was knackered after 4 years.
I have a 2010 1.4 (160), and it's battery was on its way out after 4 years as well, woulda been dead if I tried to eek it out to 5 years.
I guys, thank you for the help,
but also the low beans stay on all the time.
That's what I think is strange. Any idea?
Today I am changing the battery.
Low beams and the sidelights (bottom light with the indicators integrated cluster) are always on i think. mine certainly are. One thing that i don't understand is that my low beams are on the outside of the cluster whereas iv seen loads of Sciroccos with their DLR/low beams on with the low beams being in the middle! weird! might be a model difference.
jdizler wrote:Low beams and the sidelights (bottom light with the indicators integrated cluster) are always on i think. mine certainly are. One thing that i don't understand is that my low beams are on the outside of the cluster whereas iv seen loads of Sciroccos with their DLR/low beams on with the low beams being in the middle! weird! might be a model difference.
Cars with Xenons have dedicated DRLs that are inboard and can be switched on or off in the Settings menu within the MFD
DanielR wrote:Hi everyone,
thank you
Dan
Battery problems not necessarily related to headlights always on (but it could contribute to it). The OEM battery is terrible! I had issues with it for ages, and I opted to go for Bosch/Varta - all my problems vanished
Thank you everyone , just bought a new bosch battery and is starting much beter.
I will need to buy a vag.com cable and cd to make de change on the coding in de vcds.
Dan
