Hi
I'm looking to purchase my first Scirocco, likely towards the end of the year and until then I continue to build my knowledge.
It’s unfortunate to hear of cars being stolen or broken into for their Sat Nav systems and so I will be looking to enhance the security in an attempt to reduce the risk.
So far with help from this site, it seems that the following are recommended:
Bear Lock
Enhanced Protection Glazing (EPG)
Remap (PIN protection)
GPS Tracking
Does anybody have any other suggestions of comments on the above?
Cheers,
Ste
Security
- Roy_01
Re: Security
You could disable the key cilinders behind the covers of the doorhandle.
So they cant put a master key in it. I filled them up with aluminium foil.
And maybe a aftermarket alarm is an option. Not controlled by the canbus system.
- Irvysan
- I drive a: R-Line
- In: Ultra Violet
Re: Security
Might sound a stupid question but how do you access the cylinder for the key? I can't see an obvious way to open mine and don't want to force itRoy_01 wrote:You could disable the key cilinders behind the covers of the doorhandle.
Sent from my LG-D855 using Tapatalk
Re: Security
There is a plastic cover you prise off to access the lock in the driver's door. There is a gap your key fits into to assist prising it off.
Before disabling it's functionality, consider what you would do if the keyfob fails.
- Irvysan
- I drive a: R-Line
- In: Ultra Violet
Re: Security
Cheers I will take a closer look in the daytime
- I drive a: R-Line
Re: Security
Before disabling it's functionality, consider what you would do if the keyfob fails.[/quote]
My thoughts exactly. Its one thing preventing theft, but not at the expense of your ability to get into your own car! Twice on my old roc the key-fob didn't work, I think due to some sort of local interference and my only way into the car was by flipping off the covers and using the key.
