Fitted reverse camera PROBLEMS
markjabber
Post by markjabber »
Hi all I have fitted the Reverse camera today and having issues with it showing on screen.
It doesn't show every time it goes into reverse.
Coded with VCDS, all ok
if it is in reverse when ignition is switched on it shows the view but goes off
If radio is on and reverse selected it don't come on
Also when I have had it on it looks like the picture is upside down (will check camera placement in fitting)
markjabber
Re: Fitted reverse camera PROBLEMS
Sorted it
Camera was in housing upside down and when refitted it works every time
