Exhaust question
Exhaust question
I've got the baby Roc (the 1.4 122hp, insurance cost exempts me getting any other) and was just wondering what's the best exhaust for a nice sound? (Not too over the top boy racer-y though)
Also, do you get any gains from a custom exhaust? (Don't really know much about 'em) ... got about £500 max.
Thanks!
Thanks!
Re: Exhaust question
Been looking at either Cobra or Scorpion... any suggestions?
- I drive a: R-Line
Look at bcs exhausts St. Helens top quality sound so much better, have a look on you tube
Also, what would I need to make it same as the R exhaust? I'm guessing you can't put the R exhaust on the 1.4 tsi, no?
You'd need the rear body kit also as the R exhaust is 1 each side, not two on the left. Then you'd need the R boot lid also as I believe they are slightly different to the regular boots to fit said R body kit.
Unless i'm mistaken.
- uklee
- I drive a: GTS TDI
You're mistakenPlyphon wrote:You'd need the rear body kit also as the R exhaust is 1 each side, not two on the left. Then you'd need the R boot lid also as I believe they are slightly different to the regular boots to fit said R body kit.
nothing special (or different) about an R tailgate
- I drive a: R-Line
Is your car a facelift or pre faceliftJayPaynter wrote:Also, what would I need to make it same as the R exhaust? I'm guessing you can't put the R exhaust on the 1.4 tsi, no?
Facelift all you need to do is change the rear valance expensive mod £180 then the r exhaust fits .
Preface lift you can buy a rear valance off eBay or you have to buy an r bumper
Then the exhaust does fit
Hi, I've ended up going with an R32 style exhaust as I fancied something different... Found the valance cheap on ebay so going to get a custom exhaust for now
- I drive a: R-Line
Bcs can supply this setup for you best sounding exhaust and top qualityJayPaynter wrote:Hi, I've ended up going with an R32 style exhaust as I fancied something different... Found the valance cheap on ebay so going to get a custom exhaust for now
- Phil
- In: Night Blue
I'm worried that you have a GT rather than a R-line as les suggested further up. If you have a GT (122 is a GT) then the valance will not fit you will need a new bumperJayPaynter wrote:Hi, I've ended up going with an R32 style exhaust as I fancied something different... Found the valance cheap on ebay so going to get a custom exhaust for now
Phil
- I drive a: R-Line
I am almost sure there is a valance you can purchase on ebay it fits over the top of the original bumper but you have to cut the original one behind for the exhaust outlets I think I would agree with you and go for a second hand r bumperphiljay92 wrote:I'm worried that you have a GT rather than a R-line as les suggested further up. If you have a GT (122 is a GT) then the valance will not fit you will need a new bumperJayPaynter wrote:Hi, I've ended up going with an R32 style exhaust as I fancied something different... Found the valance cheap on ebay so going to get a custom exhaust for now
Oh, I hope not... The advert did say it was for the 122 model so it should fit.philjay92 wrote:I'm worried that you have a GT rather than a R-line as les suggested further up. If you have a GT (122 is a GT) then the valance will not fit you will need a new bumperJayPaynter wrote:Hi, I've ended up going with an R32 style exhaust as I fancied something different... Found the valance cheap on ebay so going to get a custom exhaust for now
It's all a matter of wait and see I suppose.
How much are they? I'll have a look at emlesvw123 wrote:Bcs can supply this setup for you best sounding exhaust and top qualityJayPaynter wrote:Hi, I've ended up going with an R32 style exhaust as I fancied something different... Found the valance cheap on ebay so going to get a custom exhaust for now
- I drive a: R-Line
Give Nigel a call and quote scirocco central and he wil give you a good discountJayPaynter wrote:How much are they? I'll have a look at emlesvw123 wrote:Bcs can supply this setup for you best sounding exhaust and top qualityJayPaynter wrote:Hi, I've ended up going with an R32 style exhaust as I fancied something different... Found the valance cheap on ebay so going to get a custom exhaust for now
