Language
Sabs
Options: BLUE TOOTH
Language
Post by Sabs »
Hi
I plugged my Ipod into the charger, and somehow by doing so it's changed my navigation system to German. I went into Setup; then System; then language; and selected English, but a pop-up screen saying.. "Die Gewunschte Sprache Wird Geladen..." which sits there forever not doing anything.
Can someone please help? I don't know if plugging in my mobile was actually the cause, but I can't figure out what else may have caused the system to switch to German?!
wensleydale
Re: Language
Post by wensleydale »
The message ~= "The selected language is being loaded" When I've swapped between languages (bored on a long run) it can take 5-10 minutes before it finishes. If you've not left it that long, try it again and see if it sorts itself out. If that doesn't fix it you'll need a new map disc to re-load the language files.
As for why it changed in the first place, i have no idea.
Sabs
Options: BLUE TOOTH
Re: Language
Post by Sabs »
Thanks for that, I've tried 4 separate times and all my journeys were longer than 20 mins so it just doesn't appear to be working. I'll see if the dealership has a map disc they can re-load.
