Drivers side headlight problem!
scirocco67
Post by scirocco67 »
Hey!
I have been having some problems with the drivers side dipped beam! Sometimes when I start the car, I will get a message stating that the bulb is out, but other times the message wont appear and the bulb will be working fine.
So, I decided to have a look!
When I take the rubber cover off and put my hand in, I can feel the bulb holder (I'm guessing) and If I just slightly touch it to the left, the bulb will go off, and a slight touch to the right, it's on!
Do you guys reckon I need to buy a new bulb holder ? And if I do, how easy are they to fit ? haha!
JamesE
Re: Drivers side headlight problem!
Post by JamesE »
I have the exact same problem so will be good know what others think
Instagram jamesjre94
scirocco67
JamesE wrote:I have the exact same problem so will be good know what others think
It is a pain haha! Having to open the bonnet and fix it every time I start the car
greg7728
Post by greg7728 »
Have u replaced the bulb? Know it sounds silly but I had similar intermittent issue and when took the bulb out it had blown in such a way the filaments were connected most of the time then would shake apart.
greg7728
Post by greg7728 »
Mine was a drl light though
