I was driving at the weekend and the volume on the bluetooth audio just dropped out of nowhere. I now have to turn the volume dial to max to get it anything close to how it previously was at like 2/3rds. And its still quieter than it was.
If you switch to radio is deafeningly loud. My phone has bluetooth output on max volume.
Bluetooth quiet suddenly
Re: Bluetooth quiet suddenly
Check the setting in the head unit, there's different sound levels for Bluetooth, mdi etc
Ive found the setting for AUX but nothing for bluetooth, maybe Im looking in the wrong place.
RNS 510 btw.
RNS 510 btw.
Are you using iPhone? Mine does this when location services are running in the background.
Xperia Z1.
Had a look in the menus, nothing for bluetooth volume, which is weird.
I may be wrong but I think the source volume for Bluetooth is controlled by adjusting the output volume of the phone, which is done using the normal volume control. Once you set a base volume you can then adjust the volume on the headunit.
In your case, increase the volume on the phone and reduce the volume on the headunit
Volume is max on the phone and have to turn it to max on the headunit to get any decent sound out of it.
- wensleydale
My Z1 does something similar when using Deezer. It will go quiet for a fraction of a second then resume at normal volume. I think it's an issue with the way Sony have mangled the bluetooth drivers to include PS3 controller support.Falsey wrote:Xperia Z1.
I'm waiting for the Lollipop update to be released by EE to see if this finally fixes it as each software release seems to have made a small improvement.
I get this when playing music from the iphone.
Found to be different apps at times, i just start killing them off and suddenly it gets louder again!
