There's a few issues with the car that I've got at the moment, one being that the passenger side window switch doesn't work. Now before I try to claim for this under the warranty there isn't a lock on the drivers side to stop the passenger rolling the window down is there? I can't see any button anywhere, both switches on the drivers side operate both windows fine and I've had VCDS plugged into the car which shows no change when the switch is operated so must be either the wiring or the switch itself. Is it worth sending it into a garage for this or is it a very simple job to swap it out myself?
Another issue I've discovered today is 2 hooks hidden in the boot under the rear seats behind a flap have badly rusted, this means when I put the rear seats down these rusted hooks rub on the seats and leave 2 horrible rust marks on each seat when you put them back into the upright position
