Fault p0341
Adampug11
Options: More to come soon
Fault p0341
Post by Adampug11 »
Hi, I'm new to the forum, I have just purchased a rocco 2.0 tis 58 plate with 48k.
I have searched but can't find a fault the same as mine.
Getting p0341 camshaft sensor signal non plausable.
Epc light flashes on quickly under acceleration in low rpm most frequent in sixth gear.
Just put a new sensor and same thing has happend.
Has any body had the same fault or any idea what it could be.
Garage have advised me to get the timing checked to see if the chains are stretched, is this common on the scirocco ?
adam
shshivji
In: Opal Silver
Options: panoramic roof and cruise control
Re: Fault p0341
Post by shshivji »
Does sound like timing is out tbh, stretch isn't common but has been known.
Shak
Adampug11
Re: Fault p0341
Post by Adampug11 »
Belated update but it has had a new chain and tensioner and the problem has been solved , finers crossed!
