The brake booster is making a hissing noise, so I know that needs replacing. However I’m getting an issue with the engine from time to time as well and I’m wondering if its related. It started about 3 months ago when the throttle started to surge at idle, the EPC light came on and the engine started misfiring causing the car to lose almost all of its power. I’m getting the fault code 01314 (Engine Control Module fault). The first time this happened I took it to the garage and had the throttle cleaned, coils and plugs replaced and it was running perfect again. Second time I had the throttle cleaned out and again, back to normal. 3rd time and I just let it sit for a while, cleared the fault code, and again back to normal. But it’s after happening again now and I still don’t know the route of the problem.
Think the next step will be to replace the brake booster and hope this will solve all problems.
Has anyone else faced anything similar to this before? Do you think it could be related to a brake booster leak?
