rattel noise
chippy100
In: Pewter Grey
rattel noise
Post by chippy100 »
has anyone had problem when at low rev i.e. just as go over 1000 rpm engine
makes funny rattling its
really annoying when u are start stop traffic
vw mechanic head as well but was not to sure so going in for day next week
scirrex
Options: Gt
Re: rattel noise
Post by scirrex »
Mine does this at about 1200rpm aswell. Mines going in Monday I'll let you knows sounds like a plastic rattling noise coming from nearer the passenger side.
chippy100
In: Pewter Grey
Re: rattel noise
Post by chippy100 »
mines in the middle its driving me crazy in slow start stop traffic
chippy100
In: Pewter Grey
Re: rattel noise
Post by chippy100 »
all sorted now
mine had three parts which were rattles
bonnet agaist the lock
the under tray
coolant pipe vibrating agaist the air intake
so mine now purrs like kitten
sean_87
Re: rattel noise
Post by sean_87 »
I also have a rattle noise at low revs. It seems to be coming from the rear drivers sight and is sightly squeaky in its sound so I assume it is trim related rather than anything mechanical.
Scirrex: how did you get on fixing yours?
selleym
Options: Mirror Pack
Mods:
Bonnet Struts
Metal Pedals
Re: rattel noise
Post by selleym »
chippy100 wrote:all sorted now
the under tray
Hi Chippy,
I'm getting lots of rattles at the moment. Have you got any details on how you fixed each one?
chippy100
In: Pewter Grey
Re: rattel noise
Post by chippy100 »
mine was all sorted under warranty but vw was going to charged me but it would of only been 45.00 pounds which i think it seems very reasonable
i used vindis vw in sawston very good team
jackhay
Options: Leather seats, parking sensors, carbon dash trim
Re: rattel noise
Post by jackhay »
I had a similar rattle, but a different cause, in fact I probably have some of the same ones as yours as well so I will check, but on my TDi the loudest was the bonnet stay rattling against the bracket that holds it (I hesitate to call it a hinge but that's the purpose the bracket serves). I fixed it by putting some self-adhesive insulation on the back of the bracket so the stay cannot rub against the bracket.
I think the immense low end torque of the common rail TDis which means they pull strongly from only about 1100 rpm, exaggerates vibrations at low revs. On most cars you wouldn't be applying power at such low revs.
