Fiscon w/steering wheel
Sorry if this question has already been answered guys but have just spent the past 3 hours on this forum looking for the answer and didn't find it.
Do all the functions work properly with the Fiscon bluetooth kit and the Scirocco, (the steering wheel phone button, the button on the Rcd unit etc.)
Probably ordering a Scirocco shortly and had originally intended going for the Bluetooth fitted kit until I found out that it's compatibility is literally zero. Not wanting to spend over £20g and spec the car up wrong or buy the wrong phone kit. As I say apologise if this has already been answered in a previous post
- bianco
Re: Fiscon w/steering wheel
Factory fittet:
http://www.sciroccocentral.co.uk/forum/ ... 851#p14851
FISCON Plus works fine, only the actual phone button on steeringwheel does not work.
Parrot do a couple of units that work with the radio / spekaers and seem easy to install.
They also do an interface that will work with the buttons on the steering wheel. But the wiring for the interface looks tricky and is prbably best left to an experienced fitter.
I have fitted a Fiscon unit today. Everything works, including the phone button on steering wheel. Brilliant system, easy to fit. If you buy a Scirocco, buy a Fiscon unit.
- jonallen628
You seem to be the only guy with a Fiscon kit that has the Phone button on the steering wheel working. A couple of the other lads with Fiscons have all the other steering wheel buttons functioning but not the phone button? did you install the Fiscon kit yourself? Did you have to code anything with Vagcom? Do you have the details of which software revision your Fiscon kit is using? What does the Phone button on the wheel do?claycat72 wrote:I have fitted a Fiscon unit today. Everything works, including the phone button on steering wheel. Brilliant system, easy to fit. If you buy a Scirocco, buy a Fiscon unit.
Sorry for all the questions, but your answers could be very helpful to others with the kit. I plan on getting the Fiscon kit myself sometime in the future.
Black is the new Black....
I Installed the Fiscon unit myself. I have not had to code anything with Vag-com. The phone button definately works. It Answers a incoming call and when pressed again ends the call. I guess this is what its supposed to do?
Version info as follows :-
Mainboard 1.67
143.126.133.105.107
107.108.108.111.108
Pboard 1.7
Hope that helps!
Mainboard 1.67
143.126.133.105.107
107.108.108.111.108
Pboard 1.7
Hope that helps!
- bianco
Just to be sure; Is that a FISCON Plus? And are you talking about the steering wheel button with a phone icon?claycat72 wrote:I Installed the Fiscon unit myself. I have not had to code anything with Vag-com. The phone button definately works...
Just to be 100% clear. Fiscon Plus and Button on Steering wheel with Phone Icon works!
I was very surprised it works too! after reading all posts on scirocco central, guess Fiscon must have changed something!
I do have Sat Nav, I wonder if that makes a difference? Anyone know?
Steering wheel button works fine on mine to. It is only used to answer/reject calls tho... need to use the menu (on the touch screen or MFD) for everything else.
W
W
- jonallen628
Just out of interest where did you get your kit fitted, did VW do it?willu wrote:Steering wheel button works fine on mine to. It is only used to answer/reject calls tho... need to use the menu (on the touch screen or MFD) for everything else.
W
Looks like the mainboard has been updated to 1.67 and the "phone button" works - I have mainboard version 1.50 and I have to use the "OK" button.
No issues with the OK button though!
Maybe I will return it to Fiscon for a update at some point!
This is bloody brilliant, better than my current phone stuck to the dash setup.
Brian at Car-Fi did mine in Derbyshire. I
ts great... but not cheap! I love the add on that uses the MDI to display info from the diagnositcs system (Oil temp, water temp, voltage, boost, revs, fuel).
sales@car-fi.co.uk
PS. Version comes up a v1.7
W
sales@car-fi.co.uk
W
- jonallen628
Thanks for the info, i am in Staffs so i am not that far from that fitter.willu wrote:Brian at Car-Fi did mine in Derbyshire. I
sales@car-fi.co.uk
W
Where did they put the Microphone?
Mic in on the a piller as most aftermarket kits.
W
W
- jonallen628
Cheers.
