Hello fellow Scirocco owners!
I reacently installed airlift suspension on my Scirocco, and up untill yesterday it has worked fine.
When i was on my way home, a noise from the front right wheels, and the steeringwheel is "rocking" from side to side
This goes away when im accelrating, and in low speed
Does anyone have any idea?
I think my driveshaft i broken
Re: I think my driveshaft i broken
Sounds more like the back inboard end of the wishbone. If the driveshaft was broken it would not drive just sit there spinning the broken shaft (depending on the type of diff fitted).
- uklee
- I drive a: GTS TDI
First thing I'd check is the track rod ends , and the lower arm - based on your description
