Hi All,
Car is due its service this morning and what do you know the panoramic roof switch stops working!
When I press it, instead of opening the roof it just makes a clicking sound from the console its housed in. Obviously I can ask VW to take a look at it during the service however I always fear they will charge even if its something simple.
Anyone got an easy fix? Could it be a fuse somewhere? The electric windows work just fine.
Help! Panoramic roof switch not working
- Data Ghost
Data Ghost
Volkswagen Scirocco | 170 TDI GT | Candy White
- BunnyJen
Re: Help! Panoramic roof switch not working
I've some how accidentally locked my sunroof in the past. I thought it was broken as it didn't open but I think I had maybe clicked the button a couple of times when I turned the ignition off and it's locked it? A bit of fiddling around and clicking it a couple of times again and it seemed to open. :/ Might be worth a try?
My sunroof switch stopped working today, just my luck its stuck open!
I can't close it manually as I have the interior sensors.
Did yours start working again? Or did it need repaired or replaced?
