VCDS error "Function Restricted due to Insufficient Voltage"
JohnFol
Options: 10 'plate
RNS-510
reversing sensors
Dynaudio
Disabled DRL
Post by JohnFol »
Afternoon all, a very brief background before the reams of VCDS output
I have had a 10 plate car from new that was supplied without Navigation or Bluetooth. I added both best part of 3 years back and both continue to work however I occasionally received the following error "13893632 - Function Restricted due to Insufficient Voltage".
I am able to clear it, but it now seems to be more frequent. Suspecting the battery I have had ATS check it and it shows the correct voltages (when off and charging) although also shows 80% efficiency at cranking.
One final comment, the VCDS error file below is an old one and I've included it to show the config of the car, but from memory I now only get the U1400 bit at the end and not the "Not Coded" stuff earlier on. Any suggestions:
VCDS Version: Release 10.6.0
Data version: 20100630
Address 56: Radio Labels: 1T0-035-680.clb
Control Module Part Number: 1T0 035 680 D HW: 1T0 035 680 C
Component and/or Version: RNS-MID H42 3800
Software Coding: 04050002010000AD0000
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: ------------------------- ------ ()
VCID: 2F6611E281475A64
1 Fault Found
01042 - Control Module; Not Coded
000 - -
Freeze Frame
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 254
Mileage: 16088 km
Time Indication: 0
Saturday,19,March,2011,16:06:14:46862
Chassis Type: 1K0
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 47 52 56 77
VIN: XXXXXXXXXXX
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Not registered 0001
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Not registered 0001
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 LC HW: 03L 906 022 G
Component: R4 2,0L EDC 0000SG 6175
Revision: 13H03--- Serial number:
Coding: 0001072
Shop #: WSC 00020 790 00000
VCID: 71E2D79A57F30C94
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 763B60F5492500006E0E06E892190082340000
VCID: 78F4EABE34895DDC
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_VW36.rod
VCID: 7DFAFBAA1BAB78F4
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 C HW: 5K0 937 086 C
Component: BCM PQ35 M 011 0028
Revision: BC011001
Coding: 48100A389025E100408800803400012643513B88536D81605C8000000000
VCID: 346C1E8E686179BC
Part No: 1K8 955 119 E
Component: Wischer 17120 22 0614
Coding: 009795
Part No: 1K0 955 559 AH
Component: RLS 110210 05 54 0403
Coding: 0330ED
Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Coding: 000000
Address 10: Park/Steer Assist (J446) Labels: 1K0-919-475.clb
Part No SW: 1K0 919 475 K HW: 1K0 919 475 K
Component: PARKHILFE 005 1706
Revision: 00005000 Serial number: 0 263 004 388
Coding: 100001
VCID: 3A7030B64A058FCC
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0070
Revision: 00000000 Serial number: 26011005140002
Coding: 000180
VCID: 2756F9C2A9B70224
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AE HW: 1K0 909 605 AE
Component: 0H AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 003D1D0238ZZ
Coding: 0012360
VCID: 6FE6D1E241C71A64
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 T HW: 5K0 953 569 D
Component: LENKS.MODUL 009 0122
Revision: FF010035 Serial number: 20100123200414
Coding: 1082040000
ASAM Dataset: EV_SMLSNGVOLWS A01002
ROD: EV_SMLSNGVOLWS_VW36.rod
VCID: 3D7A3BAA5B2BB8F4
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1K8 920 971 C HW: 1K8 920 971 C
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 470B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 336E1D926D6F7E84
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K102100086
Coding: E9A81F06400602004001
VCID: 69D2BFFA7F23F454
1 Fault Found
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 254
Mileage: 16091 km
Time Indication: 0
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAD040F6FA257F4C
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667798764
Coding: 010000
VCID: 2648F4C6AEBD1B2C
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 C
Component: RNS-MID H42 3800
Revision: AB001001 Serial number: VWZ6Z7Z5602354
Coding: 040500000100009D0000
1 Fault Found
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 6
Mileage: 16312 km
Time Indication: 0
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2124
Coding: 0016949
VCID: 39722FBA4F0384D4
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 178 3001
Revision: 00H17000
VCID: 3162179A97734C94
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218198835442
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1_VW36.rod
VCID: E7D639C2E9374224
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0016948
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 6
Mileage: 16312 km
Time Indication: 0
Address 77: Telephone (J412) Labels: 3C0-035-730.lbl
Part No SW: 5N0 035 730 D HW: 5N0 035 730 D
Component: Telefon 009 0511
Revision: -------- Serial number: 35909603069197
Coding: 020100010100010000000000
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_VW36.rod
VCID: 2952FFFABFA33454
End ---------------------------------------------------------------------
Thursday,28,March,2013,10:56:55:46862
Chassis Type: 1K0
VIN: WVWZZZ13ZAV436340
09-Cent. Elect. -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Coding: 0001072
Revision: 00H30001
Revision: 00003001
Coding: 0000000002
Revision: BC011001
Coding: 009795
Coding: 0330ED
Coding: 000000
Coding: 000000
1 Fault Found
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 225
Mileage: 42189 km
Time Indication: 0
Date: 2097.14.27
Time: 13:33:11
Freeze Frame:
Term 15 On
Voltage: 14.40 V
ON
ON
OFF
OFF
OFF
Coding: 100001
Coding: 000180
Coding: 0012360
Coding: 108A040000
Coding: 470900
Coding: E9A81F06500612004001
Serial number:
Coding: 000000
Coding: 010000
Coding: 040500000400008D0000
Shop #: WSC 00020 000 00000
Coding: 0016949
Component: EPS_ZFLS Kl. 179 3001
Revision: 00H17000
Coding: 0016948
1 Fault Found
U1400 00 [008] - -
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 6
Reset counter: 252
Mileage: 43341 km
Date: 2034.14.29
Time: 14:05:00
metaljay
Options: Stage 2+ Revo ;)
Re: VCDS error "Function Restricted due to Insufficient Volt
Post by metaljay »
Can you give me a up to date log?
Have you enabled 77 and 37 correctly in your gateway?
JohnFol
Options: 10 'plate
RNS-510
reversing sensors
Dynaudio
Disabled DRL
Post by JohnFol »
will try and get it done tonight. Many thanks for the offer.
JohnFol
Options: 10 'plate
RNS-510
reversing sensors
Dynaudio
Disabled DRL
Post by JohnFol »
I read a few suggestions about the SD card in the front of the unit causing problems so I have removed it. A few days later the familiar chime of an error being logged.
The following is the VCDS scan report that I have just taken and there are a few new ones there:
Friday,18,April,2014,19:20:05:46862
Chassis Type: 1K0
VIN: XXXXXXX
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Sporadic communication error 1000
47-Sound System -- Status: Malfunction 0010
56-Radio -- Status: Sporadic communication error 1000
Coding: 0001072
Revision: 00H30001
Revision: 00003001
Coding: 0000000002
Revision: BC011001
Coding: 48100A389025E100408800803400812643513B88536D81605C8000000000
Coding: 009795
Coding: 0330ED
Coding: 000000
Coding: 000000
1 Fault Found
00907 - Intervention load Management
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 5
Mileage: 68261 km
Time Indication: 0
Date: 2111.14.11
Time: 17:56:24
Freeze Frame:
Term 15 On
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
Coding: 100001
Coding: 000180
Coding: 0012360
Coding: 108A040000
Coding: 470900
2 Faults Found
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Mileage: 68095 km
Time Indication: 0
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Mileage: 68095 km
Time Indication: 0
Serial number:
Coding: 000000
Coding: 010000
1 Fault Found
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 68095 km
Time Indication: 0
Date: 2111.14.07
Time: 20:15:12
Coding: 0016949
Revision: 00H17000
1 Fault Found
9462803 - Right Front Treble Speaker
B1064 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 41
Mileage: 65814 km
Date: 2045.14.31
Time: 13:01:01
Coding: 0016948
1 Fault Found
0022 - Radio: No Communication
U1066 00 [008] - Short to Plus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 68095 km
Date: 2047.14.07
Time: 20:15:12
Any suggestions most appreciated
JohnFol
Options: 10 'plate
RNS-510
reversing sensors
Dynaudio
Disabled DRL
Post by JohnFol »
Just spotted this article.
http://wiki.ross-tech.com/wiki/index.ph ... on_System_(RNS510" onclick="window.open(this.href);return false;)_Retrofitting
If I look at my CAN HW I can see this
1K0 907 530 AD
Putting the 2 together does this mean my CAN Bus and RNS are incompatible, hence battery drain and hence the error logs?
dimexi
Options: Parking Sensors
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Windows close via rain sensor
Other Mods:
Metal Pedals
Self installed Cruise Control
RNS510
Stage 1 Bluefin
Post by dimexi »
Hello again!
Came across this thread just after I answered the other!!!
Have a look at this thread; it will give you an insight into the 00447 error code you are getting in your central electronics module.
At this point, I will assume you have coded the Nav/radio/CAN gateway modules properly and have clear the error codes that those are causing.
Any error saying: Sporadic comms/No signal etc etc is usually due to unplugging the unit or messing around with the firmware. Clear those, and see if they return.
The load management intervention kicks in when your battery charge is too low and your car shuts down non-essential items to avoid excess load on the alternator.
Hope this helps.
P.S: What I am trying to say is: Clear all error codes (after correctly coding your Nav). Go for a long ass drive or buy a battery charger to eliminate any charge problems. Monitor the situation.
JohnFol
Options: 10 'plate
RNS-510
reversing sensors
Dynaudio
Disabled DRL
Post by JohnFol »
Chaps, many thanks all for the advice. I now have a solution (so far).
Key symptoms were phone shutting down due to low voltage, random front right treble speaker open circuit and spurious "ESP Fault" messages. Battery was tested by ATS who show it Good and 85% cranking ability. Changed battery anyway and so far, 3 weeks later and no faults
