Will having air conditioning on zap power?
wintercooled
Options: Rear parking sensors
Dual climate control
Leather seats
Post by wintercooled »
Hiya, just wondered if anyone technically minded knows if having the air con on uses some of the hp from the engine? I know it increases the fuel used so I am assuming it does...
Or if you floor the accelerator does it temporarily switch it off?
Cheers, Matt
char
Re: Will having air conditioning on zap power?
Post by char »
Not sure about the temporarily disabling aircon.. but my Roc definitely is slower pulling away if the aircon is turned on, the power for it has to come from somewhere :)
rm0rgan
Options: SOLD
Post by rm0rgan »
Have to say, I don't notice any difference whether it is on or not - I'm sure they have become a lot more efficient over the years
*170 tdi torque is fairly hefty mind! :yes:
<<<< He who laughs last, thinks slowest. >>>>
Ben90
Post by Ben90 »
I've heard that it's true, but it'll only sap a few hp. I'm not speaking for the scirocco but generally I think the AC pulley is being turned all the time but when the AC is on the clutch in the pulley engages and increases torque needed to turn it as it spins the compressor too.
Mythbusters say its more energy efficient to have your windows down and aircon off below 50mph anyway :D
RoccoTom
In: Indium Grey
Options: Cruise control
Auto folding mirrors
'R' side sill strips
Luxury mats
Post by RoccoTom »
Ben90 wrote:Mythbusters say its more energy efficient to have your windows down and aircon off below 50mph anyway :D
Not that that's much use to you in the depths of winter, though! :D
Or in fact in the middle of summer.when you want the cabin temperature to be lower than ambient.
Ben90
Post by Ben90 »
Indeed, in winter I'll have the windows up and the heater on thanks! :nod:
For summer time, Ambient + wind = lower temp than ambient :) Perfectly adequate for those scorching British summer days in my opinion. I have aircon but i'll only use it maybe a few times a year in the middle of summer mainly to cool down a roasting cabin. Some people who go for big powaa bin the whole aircon system and fit a non-AC belt! 8)
Paralla
Post by Paralla »
Ben90 wrote: I have aircon but i'll only use it maybe a few times a year in the middle of summer mainly to cool down a roasting cabin.
You should use your air con more than a few times a year to keep it in good working order.
http://www.autokool.co.uk/faq_13.html" onclick="window.open(this.href);return false;
Gray170TDI
Options: Used to have one
Post by Gray170TDI »
Air con also removes moisture from the air so de-mists the windows quickly, not just a tool to cool you down in the summer. I'm sure I read somewhere it saps about 10bhp, which is very noticeable in my other halts 1.0 Peugeot 107
wintercooled
Leather seats
Thanks for the feedback.
I normally have the air con on because it stops the screen misting up in the winter and is nice in the summer.
I don't notice the power drain to be honest but I think I'll stick with my minor ocd of turning it off if I'm overtaking someone crawling along on an A road... just in case I need the extra couple of HP!
roccopanda
In: Indium Grey
Post by roccopanda »
I've just always got it on - air feels so much nicer when it's not full of moisture.
matthewlancs
Post by matthewlancs »
same here! always leave mine on......there's just something about nice refreshing dry air!
salsajoe
In: Salsa Red
Post by salsajoe »
Aircon increases fuel consumption by between 6 and 10% - the lower level being for the larger engined cars. I therefore assume that the fuel/energy used by the aircon reduces power available at the wheels by the same amount. Leaving windows open above about 50mph causes extra drag which has the same effect.
Ryy
Options: Sat Nav, Heated Leather Seats, Dynaudio, Kit with 19" alloys, 30mm Front / 20mm Rear Lowering Springs, Folding Mirrors, Interior Mats, REVO Stage 1, Carbon wrapped bits and bobs.
Post by Ryy »
I rarely, if ever use aircon.
In the 20 odd thousand miles I've done, it can't be more than 3 figures I've driven with aircon on at all.
RocMan
Post by RocMan »
With my old Civic Type S, the manual said it used 0.01% extra fuel having the air con on. It didn't zap any power and I certainly didn't notice it was using more fuel. The Rocco seems a bit different - if you go by the trip computer having the air con on reduces the instant consumption by around 10mpg. I haven't noticed any loss in power though. I leave mine on all year, for some reason most people assume air con is only for hot weather but as someone else said it demists your car in winter.
Ben90
Post by Ben90 »
Auto Express did a pretty thorough test some time ago and found that Aircon barely affects MPG at all when driven at higher speeds due to the fact the vast majority of the engine's power is being used to move the car along, at low speeds/urban driving the aircon uses a bigger slice of the power the engine is producing.
Handsfree
Post by Handsfree »
Air con is brilliant in the summer if you have hay fever. Your eyes can be streaming, 5mins in the car and you are back to normal.
Gray170TDI
Ryy wrote:I rarely, if ever use aircon.
It's widely reported that if you don't use the A/C the seals can dry up and your coolant will seep out :fall:
10minutes / week is the recommend usage. As said earlier in this thread, it's ideal for clearing misted windows and maintaining the right temperature in the summer months :yes:
Just to be clear.it's not engine coolant that would seep out it would be refrigerant gas. Although it does provide a cooling function it's not normally referred to as coolant to avoid confusion with engine coolant.
Gray170TDI
Yeah that's the coolant I meant - refrigerant
