Strange noise in cabin from dashboard/engine area
Hi iv got a tdi roc which has developed a strange noise which is cyclical and sounds like a grinding/rubbing/worn noise but not like a wheel bearing drone, its a rougher sounding drone. Hard to explain. Has anyone had anything similar or have any ideas?
Re: Strange noise in cabin from dashboard/engine area
The noise goes away sometimes when the aircon is put on but it can stikl make the noise when the heater is off. Stopped at a garage to ask a VW mechanic to listen as it had gotten quite bad. Naturally the noise disappeared when he listened. Unbelievable but typical
- whiteDevil_170
I've got 2 different noises both disappeared when I took a vow technician out to listen. Soon as I was nearly home they reappeared
Jack
Lets Roc
Funny! Annoying though
