Touch up paint.
Red201
Touch up paint.
Post by Red201 »
After washing and waxing my candy white rocco this afternoon I noticed a nasty stone chip on the bonnet. I'm off to the TPS tomorrow to get a touch up kit, my question is, will I have to remove the wax in the area I need to touch up or could the paint be applied over the wax?
Also what would remove wax? I'm thinking tar remover or clay bar?
Jay Scott
In: Pewter Grey
Options: Leather Interior, Winter Pack
Re: Touch up paint.
Post by Jay Scott »
I would definitely remove the wax before you touch in a stone chip - you don't want anything between the paint and the body that may reduce how effectively the paint bonds to the surface, I'm thinking wax, sealants, dirt, grease, etc.
To remove the wax, a strong solution of all purpose cleaner should do it (I use Meguiars APC and would probably be looking at a 15% solution), I would also de-grease and clay the area to be sure.
Before touching in the new paint I would wipe the chip and immediate surrounding area with a 10-15% IPA solution to get rid of any dirt or grease that might still be there.
alanr
In: Indium Grey
Options: GT 2.0 TDI 184 tdi r line. Black addition
Re: Touch up paint.
Post by alanr »
Red201 wrote:After washing and waxing my candy white rocco this afternoon I noticed a nasty stone chip on the bonnet. I'm off to the TPS tomorrow to get a touch up kit, my question is, will I have to remove the wax in the area I need to touch up or could the paint be applied over the wax?
Got same on my candy white bonnet :grumpy: what paint did you use mate
Red201
Re: Touch up paint.
Post by Red201 »
Cheers for the advice.
I had a go at doing it this afternoon. Doesn't look too bad. Although it does look very slightly darker, hopefully it'll settle when it hardens?
salsajoe
In: Salsa Red
Re: Touch up paint.
Post by salsajoe »
I always buy a spray can and a set of children's paint brushes and spray some paint into the top of the can cover and use an appropriately sized paint brush. Find I get a better colour match than the touch-up kits.
