Mirror Tilting Upwards
Hello Folks
My near side mirror has started to tilt upwards when I select reverse!!! It used to tilt downwards...
I tried restoring to factory settings...but no joy.
Hopefully there is an easy fix!
Any ideas?
Best Regards
J
Any ideas?
Best Regards
J
Re: Mirror Tilting Upwards
Have you tried altering while in reverse to the reverse position you want & it should then pop back up when you drive forward
Thanks Trix,
I'll try that tomorrow. Will let you know outcome.
J
J
- In: Silver Leaf
That's right, you can configure however you want it to move when you select reverse. Love that feature.
I had this on my BMW 330cd, very good option to have !
2009 2.0gt tdi 140bhp
2003 Suzuki Gsxr 1000 Rizla green/yellow (My baby) !
It worked a treat Trix...many thanks.
J
J
How can I configure tge mirrors to go down when I select reverse?
Sent from my GT-I9505 using Tapatalk 2
It's only the passenger mirror.cavido wrote:How can I configure tge mirrors to go down when I select reverse?
Tick the box in the settings menu for "reverse mirror auto dip" and then make sure the mirror adjust knob is set to passenger mirror.
On selection of reverse the mirror will move. You can adjust position using joystick. This becomes auto dip position.
When you deselect reverse, mirror will return to previous position.
From now on if you have mirror adjust knob pointing to passenger mirror and select reverse it will automatically move the mirror to stored position.
It's all explained in the manual.
Thank's
I had it enabled but the knob was always in position 0. Now I know how to do it ![Wink ;)](./images/smilies/wink.gif)
That little detail catches out a lot of people. Glad you now have it working.cavido wrote:Thank'sI had it enabled but the knob was always in position 0. Now I know how to do it
Thanks this helped me to get mine working, I was doing the same not having the thing pointed at the L position ![Smile :)](./images/smilies/smile.gif)
This feature only works on cars with electric folding mirrors.....
