Air-con not working !
Hi guys, I was under the assumption that my Roc needed regasing, I had this done on Saturday, checked all the fuses & plugged into Vagcom & found out its just not working Boo !
I have contacted my warranty company to tell them my compressor has packed up & yes it's covered yippee, so left it to my local garage who is gonna sort all the paperwork out & hopefully get it sorted ASAP.
It's 22.5 out there, balls hopefully not for too long lol
2009 2.0gt tdi 140bhp
2003 Suzuki Gsxr 1000 Rizla green/yellow (My baby) !
Re: Air-con not working !
I think this guy also had the issue...
http://www.sciroccocentral.co.uk/forum/ ... =2&t=13705" onclick="window.open(this.href);return false;
Chances are the compressor centre bolt has come loose, happened on my 2009 Scirocco. VW specialist in York wanted to replace compressor, luckily was still in warranty with VW in York who simply re-tightened bolt.
Morning Lloyd, is this an easy fix, does the compressor have to come off the car to do this ?
I'm unsure as VW did it, luckily had a few months left of warranty at the time. I wouldn't of thought it be too difficult. Case of taking the plastic trim underneath engine off and having a look I guess. One way of telling though is you can actually see the compressor above. So start the engine with a/c on. Open bonnet and look down for the compressor, it runs off the auxillary belt. Looking at its pulley you should be able to see the centre bolt. If this isn't spinning at all with the pulley that should just mean the bolt needs to be re-tightened or removed lock threaded and re done.
Had mine in the dealers for an air con fault, i.e. not cooling, they say they need the car for 3 days, to do some wiring mods , i have to say I'm a bit worried about all this, they told my wife they need to remove the dash??
My car is under warranty, this Thursday they r checking it over, ill let u no how it goes.
Morning guys, quick update with the car, had the warranty company meet me yesterday to asses my car, it's worked out to be the compressor which is covered under warranty, yay, the garage where the work is being carried out will have delivery of the new Hella compressor from Germany today, car is booked in for Tuesday to be sorted.
Very happy !
Very happy !
Well I dropped my car off this afternoon to have the new under warranty air con compressor fitted, picking it up am tomorrow, I was in no rush so left it with em YEY !
Picked my car up this morning, all is sweet nice ice cold air con !
The compressor was sent from Hella Germany last Thursday & fitted yesterday, very happy & all paid for by my warranty sweet !
