Blackberry Z10
- MikeyTSI
Blackberry Z10
My company has just gave me a Blackberry Z10 but I cannot get it to sync with my scirocco.
Any one out there have a solution?
Re: Blackberry Z10
You need to provide a lot more info for us to help.... age of car, is the Bluetooth unit VW factory unit (mounted under drivers seat) or an after-market set? If its VW which version (the earlier rsap units hardly work with anything)?
Has it worked before and if so with what phone worked with it?
- MikeyTSI
Re: Blackberry Z10
Mark
2009 2.0 tsi with factory fitted Bluetooth module. I have had a Blackberry 9810 working with no problems but unable to connect an iPhone or S3. Unit model number is 5N0 035 730 B. I presume the BB z10 uses a different version as the iPhone just fails to connect. The z10 is found by my existing module but gives a message saying the phone is not compatible
Mike
Mike
Re: Blackberry Z10
You need a new Bluetooth unit - take a look at this thread for part numbers etc... http://www.sciroccocentral.co.uk/forum/ ... 25&t=13100" onclick="window.open(this.href);return false;
- MikeyTSI
Re: Blackberry Z10
Thanks Mark I shall contact VW tomorrow.
- whiteDevil_170
Re: Blackberry Z10
eBay might be a cheaper source. Worth having a look before you try dealers
Jack
Lets Roc
Lets Roc
Re: Blackberry Z10
Very good advice! Have good search around on ebay before you even think about contacting a dealer! I have not purchased one but I hear they go for £80 to £100 - but a lot more if you buy from the dealer.... good luck!whiteDevil_170 wrote:eBay might be a cheaper source. Worth having a look before you try dealers
- MikeyTSI
Re: Blackberry Z10
£392 is a lot of money Ebay next then!!!!
- whiteDevil_170
Re: Blackberry Z10
So Mikey - how are you getting on?
- MikeyTSI
Re: Blackberry Z10
I have managed to get my S3 connected which works fine. All I did was disconnect and reconnect the connections and tried the S3 again and all worked fine so I now divert my Z10 through my S3. The real bonus is my company will pay 2 thirds of the cost of a replacement Bluetooth module so it will work out cheaper than getting one from EBay.
Re: Blackberry Z10
Good to sort it, the Z10 is a fantastic phone! Saying that so is the S3 lol
