Window seals
Henry6
Options: I added panoramic sunroof, cruise control
then VW added SatNav and leather !
Window seals
Post by Henry6 »
Hi, any advice for maintenance of the window seals on my Scirocco? Once or twice after leaving the car parked up for a couple of days I have noticed on unlocking, the windows have semi stuck themselves to the door seals. Is there a product to keep the seals non-stick? My main worry is repeated occurence will result in damagie to the window mechanism. I was offered a VW product for the Eos at £40 plus! but told it was really to stop the roof seals leaking. I have also read about applying a smear of vaseline or similar, again for the Eos. Any thoughts out there?
RisingRoc
Re: Window seals
Post by RisingRoc »
If you do a search you'll find a couple of threads on 'frozen windows'. There's also a thread on general winter prep with lots of good links. I use Gummipfledge which has done the job for me so far. Comes in a wee bottle with built in applicator so dead quick and easy to apply.
RW1
Legend
Hi from Sunny Stopfordia
Re: Window seals
Post by RW1 »
:welcome:
Hello Henry,
Welcome along.
A bit of light reading as the window seals are not the only problem when cold. ;) . Scirocco Winter Prep.
If the windows were sufficiently stuck enough, the door controller will have also registered fault codes associated with cold weather window dropping problem:
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
The Scirocco can run with these faults but a windows reset should be done as contained in the above Winter Prep link to make sure the windows will close up and not drop later.
Chris
29 Oct'09 at dealers
Driving 4th Nov. Sorted!
bobsie
Re: Window seals
Post by bobsie »
Gummipfledge works well on rubber seals. Inexpensive, and simple to use. Give it a try.
Mark V
Re: Window seals
Post by Mark V »
Just found out my 12 month old car needs a replacement door controller as the window is not closing the gap in to to the seal enough - the effect being a constant wind rustle next to the right ear....
trix935
Options: Cruise control
Re: Window seals
Post by trix935 »
Mark V wrote:Just found out my 12 month old car needs a replacement door controller as the window is not closing the gap in to to the seal enough - the effect being a constant wind rustle next to the right ear....
Glad you figured out the problem!
Have you tried the window reset in the link in RW1's post above?
Mark V
Re: Window seals
Post by Mark V »
Trix, it was discovered by Harlow VWduring the cars first service last Friday and they have ordered the new part. I thought it was just a quick adjustment needed but no....
I have nothing but praise for this particular dealership :-)
Henry6
Re: Window seals
Post by Henry6 »
Gummipfledge in the post to me now, hopefully in time for next weeks forecasted freeze.
Thanks for the links - some useful stuff.
