Had mine around 3 months now and been washing it quite a lot! Recently as the suns been out a bit more, i've noticed little scratches all over the paint. Not noticable unless the light catches them, but they're all over the car! Like some grit or dirt has got in my cloth, and i've just done it to the whole car!!
Would t-cut get it out??
I've got some of this QUIXX stuff, but thats really for isolated areas. Not the whole car!
Sounds like you might need a professional detail on the paintwork to take it back to showroom condition, and then change your car washing technique and products.
A professional detail can mean lots of things, but in respect to paintwork, it can involve using a PC (Porter Cable) to polish the paint to remove the surface scratches you are describing. Very common after using any automatic car washes, lots of supermarket car park based hand car washes, or a sponge to wash your car with (as jonallen628 says).
www.detailingworld.co.uk will help you out massively to get to grips with detailing, and all things related to car care (interior and exterior).
As I've never had a car detailed I can't help you there I'm afraid, but have a search of the DW forums and I'm sure you'll come across a company someone can recommend in your area. Or register on the site and ask
Options: Cruise Control, Parking Sensors, Folding Mirrors, Dynaudio soundpack, Winter pack, DAB & carpets plus have the First aid kit and Triangle on order.
You might need to wash the car with the two bucket method, then dry, then polish with something like Autoglym's Super Resin Polish and see how it looks. I would try avoid T-cut at the moment, as it can be very course, there are lots of finer ones out there that will not do as much damage to the paint.
You might not need to get it detailed professionally but phone around there are a few places like chip busters and that, they will be able to have a look and are normally very easy to talk to and are happy to give advise. If not go to the dealer, they normally have a few guys there that all they do is sort cars. If not they have local contacts that will be able to look for you.
Dan Fitz wrote:You might need to wash the car with the two bucket method, then dry, then polish with something like Autoglym's Super Resin Polish and see how it looks. I would try avoid T-cut at the moment, as it can be very course, there are lots of finer ones out there that will not do as much damage to the paint.
Autoglym SRP won't remove the marks but will fill them slightly so they may not be as noticeable. It is also not a permanent fix. You won't 'fix' it by hand either, a rotary polisher or similar is needed.
iambu wrote:Thanks chr15, that page was what I was hunting for to show Jonny96
You a detailing addict aswell then?
Not currently as I'm still on my first car, but like to keep up to date with things on DW, for when I get a Scirocco in a year's time (that's the plan!)
