My first post on here, after a while searching through!
Ive just got a 2.0 170tdi scirocco in rising blue - so far its been awesome!!!
however, a bit of help needed with the rns510 media unit!
Im transferring my files from itunes to the unit, via a 16gb sd card (working fine), in the File structure HDD/Music/Artist/Album/Song, and this works okay (admittedly not as slick as an ipod but hey...), but i need a bit of help getting playlists to work!
Ive exported the .m3u playlist from itunes, and realised this is set up in the file structure of itunes. Is there any way i can change this to the rns510 file structure, without manually going through each entry on textedit ? a painful process if not with a few hundred songs in each playlist!
Cheers!
Dan
