A little summary for those who have not had a really cold winter with their Scirocco. And a reminder of our experiences of the past for those already been through 2009/2010, 2010/2011 winters. Picked out the most informative topics below. Using the highlight words in the search will bring up more to look at.
Winter Prep......... Link
Frozen window prevention......... Link
Revised Window Lower Window Seal on later Sciroccos...... Link
Resetting the windows if not fully closing due to operation while frozen.......... Link
Frozen Tailgate that does not lift. Operate the key fob as usual and with the other hand, lift the tailgate as the lock noise actions. It’s usually the two sprung bump stops that have frozen. Adding lubricant can destroy them.... be aware they don’t like petroleum based products due to them being made with re-cycled plastic....... Link
A cheap snow scoop........ Link
Pack a warm jacket, water and a bar of chocolate. Water and chocolate will last the winter wrapped in a bag safely.
Also, a couple of carpet tiles cut in half, making 4 x tread mats to drive on out of a stuck situation.
Autumn and Winter wet weather, wet shoes and clothing all add up. Use the AirCon with normal heating settings to get drying air which will lift the moisture out. (NB Normal Aircon will only work above intake air of +3'C, Defrost (Aircon again) overrides down to +1.5'C) ..... Link1 ...&... Link2
Defrost mode uses the principle of removing windscreen moisture by applying dry air generated by having the Aircon switched on in this mode.
Snow socks can be handy also, either from the dealers or elsewhere such as ..... Link
Then there are winter tyres and wheels to consider. Even on max tread depth normal tyres, the Scirocco is not nimble on snow
And not to forget the Windscreen wash. Needs the solution strengthening against freezing in colder weather.......
Link1
Link2
Particularly those who have headlight washers in the front bumpers ........ Link
