Fitting a Speed Limiter
- Location: Durban, Kwa-Zulu Natal,Republic of South Africa.
My Rocco has got the standard speed limiter,which is just a barely audible sound/ alert that warns that you have reached a set speed. Most of the time I am unable to hear it. Other cars I have owned had a system that prevented further acceleration past the set limit. Is it possible to retro fit such a system ?
- bianco
Re: Fitting a Speed Limiter
Set wintertire warning to the speed you need. Then you get a beep and text warning in the mfd.
I have got that. It is available via the MFD. However it is just a warning "gong" that is barely audible. The text message is not really helpful either, as it acts more as a distraction. I am wanting to be able to set in a specific speed, and when that is reached further acceleration is denied. When I had the Stage 1 APR fitted it was programmed so that it's various settings (Advanced/Original/Valet) are activated via the Cruise Control on and off switch. There must be a VAG setting that can be retro fitted to carry out a proper speed limiter setting.
Not on petrol. And on diesel if you lower it, it stays lowered perminantly, can't be raised again.Essenwood wrote:There must be a VAG setting that can be retro fitted to carry out a proper speed limiter setting.
You will need to go the APR way... if the tuner puts the facility with their re-map. Not seen one for recent TSi.
My satnav (Navman) has a function that can be set to give both a noise and a verbal warning when you exceed whatever speed you set into the system. I only discovered this when my daughter set it 'for a laugh' and of course you can ignore it so it's not a proper limiter but it does give quite a loud warning.
