Few mods i would like to do
Anyone know how much scirocco r wing mirror covers are?
GT insert for steering wheel code and cost?
R rear lights cost and code?
Black surrounds for dash inserts cost and code?
Re: Few mods i would like to do
have you tried using the search >>^^
Yes i have and no real definitive answers.
- bianco
Go look at the Roccopedia (link above right), and also try your search again.
Re:
http://www.sciroccocentral.co.uk/forum/ ... cap#p44564" onclick="window.open(this.href);return false; yes from VW unless you might find some from a breakersrscut wrote:R Wing mirror covers 3C8 857 537 GRU and 3C8 857 537 GRU (presuming from VW?)
http://www.sciroccocentral.co.uk/forum/ ... heel+badge" onclick="window.open(this.href);return false;rscut wrote:GT insert (roccopedia link to vagparts doesn't work)
http://www.sciroccocentral.co.uk/roccop ... rt_Numbers" onclick="window.open(this.href);return false;rscut wrote:R rear lights cant find a price on here or a part number
Re:
Would help if you said what Scirocco you had in your profile.rscut wrote:Inserts another dead link or 1Q0 858 069H 041
The above is for the MY2010.5 - MY2012 Scirocco where the heater controls show in the radio/CD (Nav) screen as graphics.
I presume cos you are asking for the old MK5 Golf steering wheel insert, its a '58 plate/early '09 Scirocco with RED MFD dash insert .... The MY2009 (Aug'08 - April'09 build) with 3 rotorary heater dials is 1Q0 858 071F. Not available in Piano Black only Satin Black finish in code option L88. Without code its a satin silver finish as per the Scirocco.
What people do is... sand the panel down with very fine paper to key the surface for spray paint shiney black, wait for paint to harden properly, sand down again for smooth finish, clear lacquer spray, wait for lacquer to harden properly, sand down again and final top coat of clear lacquer.
If you keep an eye out on Ebay for EOS items, you can pick up the panel and 3 UK RHD trim strips. I paid peanuts for a set a while back in two auctions. The radio panel cost me £1.
And Mirror Caps btw are 3C8 857 537 GRU and 3C8 857 538 GRU. Same as the ones you have fitted.
Gt Steering wheel badge P/N 1KO 419 685Q 3Q7 RRP £21.59, got mine from TPS yesterday.
Whats tps mate?
http://www.thetradepartsspecialists.co.uk/" onclick="window.open(this.href);return false;
Another arm of VAG supply in the UK.
Some are OK, others are trade only. Depends on your local branch.
