Rumbling from rear
Rumbling from rear
Anyone had a rumbling from the rear at motorway speeds before? Seems to be louder when when decelerating, not sure if its the diesel exhaust or tyre noise, the TSi never made a noise like it
- chrisyboyc
Re: Rumbling from rear
run your hand around the rear tyres i fel for a buldge if you find one thats your noise it seems to happen a lot and has to me
If you see S9 CTC driving around give us a wave I do 40,000 miles a year it gets lonely out there
I hope not, ive only just picked it up from dealer!
As I said on the other forum I get it too and put it down to the Pirelli P Zeros as it changes with road surface.
I noticed a strange sound coming from the front of the car. Not a rumble as such, and not all that perceptible. On Tuesday I had some new P Zero Rosso's fitted and the sound has gone.
Hows about swapping the rear tyres to the front, see if that makes a difference...
Mind you, if you've only just picked it up, then yeah, perhaps it should go straight back for them to check.
Hi bushier
Yeah, as chrisyboyc said it is a bulging of the inner edge of the rear tyres, mine has the same fault (apparently a common fault according to my local tyre shop), not sure if swapping them to the front would fix it or not.
Certainly take the car back to the dealer and see what response you get.
Regards
Martyn
Regards
Martyn
As said earlier in the thread, it is the tyres, they are worn eneven so they swapped them and although better its still there, they say itll get better as they wear, had dunlops for years and never had this before so defo gonna be getting them when these are worn!
So what does the wear on the tread pattern look like? Centre worn, outer edge worn, inner edge worn? Both tyres or which side?Bushiee wrote:As said earlier in the thread, it is the tyres, they are worn eneven so they swapped them and although better its still there.
Usually when this noise occurs the tyre has stepped which means the centre has worn more than the outer edges. some blame over inflation but most regard this as a general problem with the Mk5 chassis..
R
I didnt get a look on the ramp but when i looked they looked ok, maybe the inner edge is more worn than the rest but as far as my eye can see they didnt seem too bad, especially to warrant a racket like they were making!
I'm just wondering if the 'toe' setting is set wrong on the rear axle causing the tyres to be dragged slightly. Which why I asked where the wear was.
RW1 wrote:I'm just wondering if the 'toe' setting is set wrong on the rear axle causing the tyres to be dragged slightly. Which why I asked where the wear was.
Yeah it is strange one. I had it so bad on mk5 gti it drove me to get rid of it
![Thumbs Down :no:](./images/smilies/thumbsdown3d.gif)
R
