Using DSG
Lloydyboy
Options: Black Leather Seats, Rear Parking Sensors, Premium Door Sills, Scirocco Floor Mats Winter Pack, Flux LED's
Using DSG
Post by Lloydyboy »
Hi guys
I know this may seem like a ridiculous question but I was just wondering if you's have any tips/suggestions when using DSG/Auto.
I have always driven a manual car so although auto makes things much simpler there's still things I'm wondering about, for example;
When reversing is it good to switch straight to D while the car is still rolling back? then let the car (without putting any rev's down) pull itself forward? - little things like that I'm wondering about really so if anyone like I say has any tips or anything then will be much appreciated - if I'm asking a load of rubbish then just let me know ha
Lloydyboy
bianco
Options: All except sunroof, ACC, Dynaudio & rear seats. Lowered a bit for the looks :-)
Re: Using DSG
Post by bianco »
Nothing special actually.
You will soon enough find out that it crawls forward if You do not hold Your foot on the brake at the light ;)
When changing between forward and reverse, it is always a good idea to stop completely - regardless of transmission.
skyblues11
tyre indicator
Re: Using DSG
Post by skyblues11 »
If you by accident, selected N , just don't accelerate. Let the rev drop and then re-select.
I use the auto D in traffic jams or motorway, but use the + and - on A roads. i like the choice of gears and the paddle shifts are really useful.
when you appraoch a round about, be careful if you are on manual mode. Instinctively you would drop the gears as you would with a standard manual gearbox, but the DSG drops them for you as you brake. This is one situation where you cannot choose to stay on a 4th for example. It will decide. Often i end up revving like crazy on 2nd because when i brake from speed, i don't know what gear it has dropped to. I have to upshift quickly to avoid wheel spinning.
If you are in a hurry , click on S and put on Sport on the ACC. Enjoy!
bianco
Re: Using DSG
Post by bianco »
One detail not everybody knows:
If You push the gas pedal to the floor, it gears down to give You some go :)
But if You press hard on the pedal, it will go 2 mm more, and it feels a little like a push-button. This is some sort of Oh-Shit! function, that immediately gives You max power - It will downshift till it reaches approx. 5.000 rpm, and go like Ohhhh!!!
Not very comfortable, and no good for a smooth flow on the track - but it will get You out of a bind.
