Brakes
Brakes
Hi all,
Just bought my Scirocco 59 plate 2.0 tsi auto, from an approved dealer, My concern is when i brake it sounds like the rear brakes are grinding is this normal? the car had a service the day before it was handed back to the dealer and has had it's checks before i was allowed to drive it away the car has covered 9400 miles.
If there was a problem with the brakes would this not show on the display as a fault/check?
Thanks in advance
Thanks in advance
Re: Brakes
Could be due to the car being parked up for a while, give it a good drive with some heavy braking (making sure there's no-one close behind).
Re: Brakes
I wouldn't worry too much about that with the standard brakesIan_Mac wrote:Could be due to the car being parked up for a while, give it a good drive with some heavy braking (making sure there's no-one close behind).
![Tongue :p](./images/smilies/tongue.gif)
- Moderator
Re: Brakes
carlpea wrote:I wouldn't worry too much about that with the standard brakesIan_Mac wrote:Could be due to the car being parked up for a while, give it a good drive with some heavy braking (making sure there's no-one close behind).
![Confused :?](./images/smilies/confused.gif)
Re: Brakes
not compared to the opposition on a car with sporting pretentious, real lack of progressive feel, callipers are where the issue is as two pot and heavy, the R set up is far more reassuringskippy wrote:Standard brakes are very good, tad confused with that statement
Re: Brakes
I cannot say for fear of ridicule what my last vehicle was, but it was a 4x4, weighed 2 tons and had rear drum brakes, when I went for a test drive in the Sirocco and hit the brakes, I thought I was going to put me and the Mrs through the windscreen, I hit the brakes like I would in my old truck and that was to get it to slow down never mind about stopping. Scirocco brakes to me anyway are brilliant.carlpea wrote:I wouldn't worry too much about that with the standard brakesIan_Mac wrote:Could be due to the car being parked up for a while, give it a good drive with some heavy braking (making sure there's no-one close behind).
Re: Brakes
The grinding noise usually go away with one hard brake from say 40-45.
I belive it is from brake pad residue on the discs. Happens to mine when I haven't driven/braked hard for a while. Same with my old Golf 2,0 FSI
Re: Brakes
Same for me too if i havent driven the car for a while, a hard break usually clears the problem.polo classic wrote:The grinding noise usually go away with one hard brake from say 40-45.
Re: Brakes
skippy wrote:carlpea wrote:I wouldn't worry too much about that with the standard brakesIan_Mac wrote:Could be due to the car being parked up for a while, give it a good drive with some heavy braking (making sure there's no-one close behind).
Standard brakes are very good, tad confused with that statement, but grinding noise not normal. Build up of rust on the discs perhaps, but this should clean up very quickly.
I used to have a Clio 200 so that could explain it...
- buster
Re: Brakes
lloydie63 wrote:I cannot say for fear of ridicule what my last vehicle was, but it was a 4x4, weighed 2 tons and had rear drum brakes, when I went for a test drive in the Sirocco and hit the brakes, I thought I was going to put me and the Mrs through the windscreen, I hit the brakes like I would in my old truck and that was to get it to slow down never mind about stopping. Scirocco brakes to me anyway are brilliant.carlpea wrote:I wouldn't worry too much about that with the standard brakesIan_Mac wrote:Could be due to the car being parked up for a while, give it a good drive with some heavy braking (making sure there's no-one close behind).
I would go along with that, though we came from a volvo s40 i still remember the look terror on the salesmans face
![Eek :eek:](./images/smilies/eek.gif)
![Clap :clap:](./images/smilies/clapclap.gif)
but i would certainly not let any brake noise go unchecked for long.
Re: Brakes
For me I think the brakes are the worst dynamic aspect of the rocco package - the stock ride height being the worst looks issue.
The brakes are fine in normal driving but anything else and they become a bit iffy. Had to do an emergency stop from speed once and I was not overly impressed at all.
Some sort of brake upgrade is definitely on the to do list.
playing in my '86
