hi
i want to connect v1 to power from map lights console
i am looking for a guide that explain how to remove map lights console.
thanks...
- mat
It's easy - the panel that covers the alarm sensors flips down. Under there, you will find 2 torx screws.Dannyc wrote:hi
thanks...
Just undo those, and the whole panel comes down.
Re: remove map lights console
ok... from which side should i start open the panel ?
thanks!
thanks!
- mat
Just behind the flip down sunglasses compartment - you should see the sensors.
You need either long fingernails or a plastic tool (so you don't scratch anything) - just gently prise the sensor cover down - gently now!!
Don't try to prise the sensors themselves, it's the plastic cover over them.
Looking from the back seats, the cover has 2 hinges at the back of it (hidden from view until you release the front clips of the panel) - to release the front clips, just work something plastic In between the panel and sensors.
Note - if you're trying to prise anything at the roof lining, you're in the wrong place.
i connected my valentine one to the mirror, and i want to take power from map lights.
do you think it's a problem ? because there is switch power that i need
thank you very much...
