Just an update guys, looks like I spoke to soon!
Basically it was the injector that caused the problem. But when they replaced it the lumpy idle wasnt completely fixed. So they looked deeper, took the head off to have a look inside the engine for any damage.
They said the injector has been spraying fuel incorrectly so that the piston had heated up too much and caused the valves to become burned and so much so that the bore of the engine has become out of shape. Therefore... NEW engine. New block, new pistons, new valves, new injectors new everything! Other than ancillaries (AC, power steering etc.). All the parts they need should be with them tomorrow/monday latest. And they reckon it should be done next week.
I'm glad they looked deeper into it and found the problems the injector had caused. And I'm happier that I'm getting all new components rather than half and half, with some old components left in I couldnt help but think something else might go wrong!
Just to re-iterate, look into you cylinders if you have any lumpiness or odd going's on with your engine! Insist VW check it out as it was only after Chris and I found the markings in Cylinder 1 that they looked into it (before this they gave the typical "no fault codes found")
Thanks Chris for helping me point them in the right direction. And thanks to VW Heritage Bristol, daily updates and timely work and a good resolution (not good, but got to the bottom of it!) Very impressed by the support I've received
Now I get to run in the engine as if new...
