OK, If one wheel is a little faster than the rest, then it is probably flat, and turns on the warning light.RW1 wrote:bianco wrote:The ABS system checks the rotation speed of the individual wheels.oferelijah wrote:how can i know if i have a tyre sensor in my wheels?
If one wheel is a lot slower than the rest, then it is probably skidding, and the brake on that wheel is released a little.
The Tyre Pressure Monitoring System is a piece of software, that takes the same ABS systems information and says:
If one wheel is a little slower than the rest, then it is probably flat, and turns on the warning light.
It just needs to be reset, to know what "normal" is, when You change tyres.
Therefore, the Tyre Pressure Monitoring System does not need any additional hardware. Just the reset button.No skidding. Does not spin slower.
The systems initially takes its calibration from pressing the Tyre Pressure Indication switch on the assumption that the tyres have been first checked for correct pressure.
If the tyre that is going flat, it has an effective smaller diameter and therefore smaller effective rolling circumference of the tyre. This results in the wheel speeding up and the wheel's ABS sensor register's this.
The algorithm in the ABS calculates over a short period of time each wheels characteristic following calibration. So recognises a tyre deflating by the rotational increase in speed. At a specific tolerance, the system warns. The warning can also occur due to abnormal loading of the Scirocco on one side or anything that changes a tyre's effective diameter.
No braking or releasing of brakes is involved.
Flat Tyre indicator - Retrofit
- bianco
Re: Flat Tyre indicator - Retrofit
- Chillout
bianco: how did you find out about the coding bit? Because as far as I know, the Scirocco ESP-module is not documented (yet)... or do you have a modified labelfile for it?
- bianco
Well, tried 27 as the Golf instructions said - no diceChillout wrote:bianco: how did you find out about the coding bit? Because as far as I know, the Scirocco ESP-module is not documented (yet)... or do you have a modified labelfile for it?
Found the elecronic diagram that someone posted earlier in this thread, it says pin 35. That did the trick
It was bloody hell to get the wire out from the wrong hole though!
PS It has nothing to do with the ESP system. It is part of the ABS system (not being an authority on the subject).
- Chillout
No, I meant... How did you find out about the the Vagcom coding bit...bianco wrote:Well, tried 27 as the Golf instructions said - no diceChillout wrote:bianco: how did you find out about the coding bit? Because as far as I know, the Scirocco ESP-module is not documented (yet)... or do you have a modified labelfile for it?
Its documented in VCDS v10.6.0 / v10.6.1.
Controller 03 - ABS Brakes.
"select the second to last bit/field." in the Roccopedia might be better expressed as "Select Byte 16 and set Bit 2."
- Chillout
I know how it works, but thanks for the infoRW1 wrote:Its documented in VCDS v10.6.0 / v10.6.1.
I have a clone cable at the moment, so I dont use the latest version yet... are there any more things inside the ABS coding?
Nothing documented as selectable 'bits' other than LHD/RHD model selected in Byte 15 and the above Byte 16 TPMS 'bit'.
- bianco
The Guide is now so polished, it might as well be chromedRW1 wrote:Its documented in VCDS v10.6.0 / v10.6.1.
http://www.sciroccocentral.co.uk/roccop ... e=Fit_TPMS" onclick="window.open(this.href);return false;
hello,
Sorry to ask but I would like to know which are the 3 wires from ESP button you have plug in the little black connector and if the order is important? Because according to the Kufatec instructions it must be:
-the grey one for" light"
-the brown for "earth"
-the black/green for "+"
But you've said the black/green stays in the esp connector and what about the last wire from esp which is purple/green? so i don't know exactly what to do...
If someone could give me some precisions.
Thank you and sorry for my english i'm from Corsica.
- Chillout
Leave the purple/green one in the ESP button please. And yes, it is REALLY important that you put the right cables in the right place.
Ok thank you very much "Chillout"
When purchasing the kit from kufatec what options do you select....
incl. push-button
Golf 5 V
2008
Are the above correct?
incl. push-button
Golf 5 V
2008
Yes it's correct.
Hello,i did the installation but I have another problem, I have vcds 805.4 and in byte 16 there is no information so if someone with TPMS could show me ABS long coding or coding of BYTE 16 checked with TPMS thank you
What are your 8 binary bits parttern showing at present in the Byte 16 window?
- bianco
Could someone please take pictures of the wirering of the buttons before and after?
Hello RW1, here you can see my vcds log:
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 743B60F5092200002E0D06ED901C00403000
And on Byte 16: Binary: 00110000
Revision: 00H35001
OLD:eric2b wrote:Hello RW1, here you can see my vcds log:
Revision: 00H35001
Long Code: 743B60F5092200002E0D06ED901C00403000
Byte 16: Binary: 00110000 ie “30” in the long code
NEW:
Long Code: 743B60F5092200002E0D06ED901C00403400
Byte 16: Binary: 00110100 ie “34” in the long code
To change a bit without the Bit tick box being present, you change the relevant binary bit from 0 to 1 by overwriting the 0 to a 1 in the Binary Field to get the revised binary pattern, follow the instructions here
(NB. Wise not to change other undocumented bits in the controller units as some do not revert. Red face at the dealers to ask for a controller re-programming!!)
Thank you very much RW1 for your quick reply, I will try tonight
Yes It works!!
Now I can see the icon of TPMS in the instrument cluster, it lights up for a second when I start the car.
If I hold the TPMS switch the icon in the instrument cluster lights up, once it turns off after 3 seconds I release the TPMS switch and I can hear a ‘ding’ coming from the instrument cluster. So normally It means the system is ok!!
Now I have to test on the road.
