MY Viper Green Scirocco 2.0 TSI from Italy < IROC project >
Rune9019
I drive a: 1.4 TSI 122/125
Re: MY Viper Green Scirocco 2.0 TSI from Italy < IROC projec
Post by Rune9019 »
Alien_IROC wrote:Thanks, it's a long work but the result is fantastic!
Other important upgrade i done, was the TTRS brakes, big difference from stock brakes, give the stopping power that the 2.0 TSI should need!
Discs are Zimmerman SPORT 350x32mm front and 310x22mm rear
Custom paint Audi Ara Crystal with custom VWR stickers
Installed brakes and coils
Did you have to change anything to get these brakes working, i'm thinking of abs pump or brake pump - don't know the right name, but is the stock one good enough for these brakes?
Alien_IROC
Options: ....IROC project....
@vw_iroc_project
Post by Alien_IROC »
I haven't change other parts, i tried only to recalibrate the ABS module with VCDS software, you can code the dimensione of the brakes, but didn't work, need another software....
Someone say that is good idea to upgrade to the R or S3 ABS pump, because have a larger master cilinder and so bigger pressure on bigger calipers....but actually in the VAG scene i haven't seen someone doing this upgrade.
So you can keep the stock system, i use the car also in trackdays and the brakes work always perfectly.
Rune9019
Post by Rune9019 »
Alien_IROC wrote:I haven't change other parts, i tried only to recalibrate the ABS module with VCDS software, you can code the dimensione of the brakes, but didn't work, need another software....
Thx, really good to know.
And what do you think of the headlights? I have halogens on my car and would like some fairly cheap but still good looking headlights, but i dont really like any third party headlights except those you have - are they any good?
Alien_IROC
@vw_iroc_project
The headlights are low quality build, i have the first production probably and they have various defect. But in any case, they are better than the standard halogens.
Rune9019
Post by Rune9019 »
Alien_IROC wrote:The headlights are low quality build, i have the first production probably and they have various defect. But in any case, they are better than the standard halogens.
Atleast they are an upgrade.. but how do the love and high Beam Work - both in the de lens?
Alien_IROC
@vw_iroc_project
Yes they are bi-function (low and high beam) with H7 soket, so you can put halogen H7 or xenon hid H7 or LED bulds H7
Rune9019
Post by Rune9019 »
Alien_IROC wrote:Yes they are bi-funciton (low and high beam) with H7 soket, so you can put halogen H7 or xenon hid H7 or LED bulds H7
Alrighty, thank you :-)
Keszeg1
Options: 1.4 TSI 160, Candy White, Manual box
Post by Keszeg1 »
Hey!
Very nice build i really like it u did a fantastic job with ur rocco.
I would like to ask u if u could send a few pictures about the headlights at night and how bright are they in dark?
Im interested buying them for my rocco thats why i want to see how they perform at night.
Alien_IROC
@vw_iroc_project
Hi, thank you!
I've recently removed this headlight and installed the OEM look Bi-Xenon, produced always by DEPO.
At night they are good only with HID Xenon lamp, you can see very bright also in total dark roads.
Kamil8865
Post by Kamil8865 »
Awesome project.
What material did you use for the rear diffuser and front splitter?
Keszeg1
Post by Keszeg1 »
Alien_IROC wrote:Hi, thank you!
And how much better is the OEM compared to the Aftermarket one?
Alien_IROC
@vw_iroc_project
Kamil8865 wrote:Awesome project.
Thanks, the material is plastic called PVC forex
Alien_IROC
@vw_iroc_project
Wait, i don't have OEM VW Valeo now, but they are always DEPO that look like Valeo VW.
I have also a VW Golf MK5 with OEM Hella headlight and i can say that the visibility is almost the same.
Alien_IROC
@vw_iroc_project
It' a lot of time that i don't update here, :( so i post some update from the last months. :D
Installed OEM Recaro and i made also new seat belt in green! Love them!
eenbadendaap
In: Dark Oak
Post by eenbadendaap »
Nice upgrades for the car ! Like I’m looking at the iRoc concept.
Any new upgrades planned for the future ?
Alien_IROC
@vw_iroc_project
Thanks! There are planned A LOT upgrades! :D
First of all i have to change the clutch just in these days, i think i will install Sachs Performance full KIT.
Next upgrade will be probably a stage 3 tune with K04, intercooler and others....
Also i would like to install a new LSD, wavetrac or Quaife .....
Next next, bigger sway bar, full kit of strongflex, and front aluminium Audi TTRS spindle and arm.
eenbadendaap
In: Dark Oak
Hahaha that's crazy ! Well, keep us up to date. It's nice to see that the Scirocco is still much alive !
Kamil8865
Post by Kamil8865 »
Colour seat belt are a nice modification!
I have blue in my R :)
Alien_IROC
@vw_iroc_project
Fantastic! Also with Recaro like mine is the TOP!
The body of the car is also blue?
Kamil8865
Post by Kamil8865 »
Alien_IROC wrote:Fantastic! Also with Recaro like mine is the TOP!
No. My car is white, but it's R and I have blue needles and some interior parts ;)
