Marius Rocco
JoeSmith26
Re: Marius Rocco
Post by JoeSmith26 »
Marius, would you be able to make a detailed guide on the installation of the discover media unit? Ive been searching for about 2 hours, and can't find much. I've just bought a unit with CP activated as it seemed better value (big mistake) so i understand that I cannot patch it, and have to get VW to remove CP, but in the process they deactivate all the features. So, the only route I can see is to:
1. Replace the old Can gateway to one with access to 5F (7N0 907 530 AM/AN/AH/AK/AL/AJ/AG)
2. Install the headunit,
3. Go to VW dealership and ask them to remove CP.
If you could either correct me, or list some steps, then that would be great.
Marius336
I drive a: 1.4 TSI 122/125
Re: Marius Rocco
Post by Marius336 »
i buy my DM from VCDSWorkx compleat with CP remove and all things. Appconect, voice control.
https://www.facebook.com/VcdsWorkx/" onclick="window.open(this.href);return false;
i have 7n0 BC gateway, because of the assists. that alrady support 5f.
VW will not remove CP, at least here in germany not....
Marius336
Re: Marius Rocco
Post by Marius336 »
I chnage the old stalks to new Passat MQB stalks, also i now have Cruise Controll on steering wheel.
Roy_01
In: Sumatra
Re: Marius Rocco
Post by Roy_01 »
Looking great! Is that a custom steering wheel control module or canbus interface?
Marius336
Re: Marius Rocco
Post by Marius336 »
the modul is from spacewalker
it translate the Steering wheel button data in the old stalk data, so the ECU can understand it.
Marius336
Re: Marius Rocco
Post by Marius336 »
got the new wheels on. But i think the Tirepressure is wrong, because the the reciver is in thge wrong spot
Marius336
Re: Marius Rocco
Post by Marius336 »
Finaly i got the R bumper on.
vladandrei51
In: Night Blue
Options: REVO Stage 2
Wossner Forged Pistons
Fox Sportauspuff Quad-Exhaust
VWR VW Racing CAI
3" catless downpipe & 3" catback (custom)
S3 intercooler
De-Cat / De-Res
03C906036M Injectors
NGK BKR7EIX Spark Plugs
NGK U5002 48003 Coil Pack
Revised Timing-Chain
Re: Marius Rocco
Post by vladandrei51 »
Hi Marius,
Dope car. What springs are you using? :D
Marius336
Re: Marius Rocco
Post by Marius336 »
vladandrei51 wrote:Hi Marius,
Coilovers. Vmaxx, not the best, maybe i change to KW.
Rune9019
Re: Marius Rocco
Post by Rune9019 »
Marius336 wrote:Got my rear painted.
new Wheel
And Cluster Update
Does your tailgate open by the logo, and if it does, how did you do it?
Marius336
Re: Marius Rocco
Post by Marius336 »
Yes it do.
i pull one wire from Tailgate to the BCM. Plug A Pin 13
davidscirocco
Options: panorama tilting roof, electric
"interlagos" alloy wheels
sport pack
RCD 510
air-contition Climatronic with dual- zone climate control, left and right side separately controllable
Re: Marius Rocco
Post by davidscirocco »
@marious336 have you manage to make the turbo cluster work?
Marius336
Re: Marius Rocco
Post by Marius336 »
yes, i got this activated by a chip tuner.
vladandrei51
In: Night Blue
VWR VW Racing CAI
S3 intercooler
De-Cat / De-Res
Re: Marius Rocco
Marius336 wrote:the modul is from spacewalker
Could you please elaborate on this?
I have a mk5 golf-like steering wheel with no buttons on it and today is supposed to arive my R-line steering wheel. I'm wondering what I can do to make the buttons + illumination work
Marius336
Re: Marius Rocco
Post by Marius336 »
dont work with 1k0 steering wheel modul.
my car alrady have 5k0 steering wheel module, so the new E steering whell works without moule.
The module is onle for the Cruise Controll buttons.
Rune9019
Re: Marius Rocco
Post by Rune9019 »
Marius336 wrote:dont work with 1k0 steering wheel modul.
Would that steering wheel control unit work on a red mfd?
And is it this part you're talking about when saying 5k0 and not 1k0?
https://www.ebay.com/itm/VW-OEM-steerin ... 0985389335" onclick="window.open(this.href);return false;
Marius336
Re: Marius Rocco
Post by Marius336 »
Scirocco under 2010 have 1k0 Clockspring. Scirocco Over 2010 have 5K0 953 569 Clockspring.
if you want tu use a new steering wheel on 1k0 Clockspring, you need:
1K0-959-653-C and 1K0-959-653-D
and you need new Steering controll module:
1K0-953-549-CD/CH/CK
With this setup, the MK6 Steering wheel and the Scirocco Facelift wheel will work.
there is only the Problem with the Scirocco Facelift steering wheel, that the light dont work. Maybee google will help for that, Google: MK5 MK7 steering wheel lighting. You have to solder a smal bride so the light will work.
5k0 Clockspring everything works plug and play. But the conversion from 1k0 to 5k0 is hard.
Rune9019
Re: Marius Rocco
Post by Rune9019 »
Marius336 wrote:Scirocco under 2010 have 1k0 Clockspring. Scirocco Over 2010 have 5K0 953 569 Clockspring.
So if i want the mfsw buttons to work, i will need -
1K0-959-653-C
1K0-959-653-D
Right?
Lets say i want to upgrade my cluster to a facelift version further down the line - would the multifunction buttons still work with that display?
Marius336
Re: Marius Rocco
Post by Marius336 »
yes the buttons will work.
i made a mistake in my last post: its 1k0 959 653 C ORE D not both
Rune9019
Re: Marius Rocco
Post by Rune9019 »
Marius336 wrote:yes the buttons will work.
Oh okay, and i guess with 1K0-953-549-CD/CH/CK It wont matter if it ends in CD, CH or CK?
