Power mirror fold using the fob ? EDIT -You need Vag Can Pro
unclejosh
Re: Power mirror fold using the fob ? EDIT -You need Vag Can
So it needs to be long press?
cause i have seen some scirocco that folds the mirror upon locking and not long hold.
not sure how they did it. or maybe they long press it without me realising?
is this the only option? long hold to fold the window?
ganmo0409
* Car information
2.0Tsi (DSG, RHD) from Japan
* Module information
Address 42: Door Elect, Driver / Lovels: 1Ko-959-701-Max3.clb / Part No SW: 1Q0 959 701 H
Component: Tuer-SG 009 2116 / Coding: 0152439
Address 52: Door Elect, Pass./Lavels: 1Ko-959-702-Max3.clb / Part No SW: 1Q0 959 702 H
Component: Tuer-SG 009 2116 / Coding: 0152438
* I'm worried about three codes.
ROM was rewritten by simple setting of VCP (one click?).
The mirror did not fold with the key.
However, when I lowered the window and pressed and held the key, the mirror was folded.
Of course, the window also goes up.
When I checked the values in VCP engineer mode, the three codes were "D4".
I tried "D2", but it is in the same state.
The "D3 & D6" mirror has been flipped.
Please give me some advice.
sciroccomods
- I drive a: R-Line
Are you just trying to code the mirrors to fold on the fob using vcp, if so its simple, let me know and ill tell you what to doganmo0409 wrote:* Car information
I offer Power fold mirrors installs, Cruise control installs, Coding, mirror folding on keyfob etc. i'm in Stockport,Manchester
ganmo0409
to addy73addy73 wrote:Are you just trying to code the mirrors to fold on the fob using vcp, if so its simple, let me know and ill tell you what to doganmo0409 wrote:* Car information
I coded with VCP, but the behavior is strange.
With the window open, press and hold the lock button on the remote control to fold the mirror.
The mirror cannot be folded when the window is closed.
I'd like to ask for work, but unfortunately I live in Japan.
sciroccomods
- I drive a: R-Line
when you coded you did just do it from the guided functions didnt you, if you didnt and you can undo what you have done i can then help you code them, its very very simple.
Blanco92
Hi, are you still offering this? I'm <sometimes> Gatley based. Have VCDS but not VCP...addy73 wrote:Hi, I can offer this service in Stockport using a genuine vag can pro. you will need folding mirrors that fold on the switch, I can then programme them to either unfold on the keyfob, or unfold when you start the car, £30.00 thanks.
sciroccomods
- I drive a: R-Line
Yes, im in cheadle prob once per week so could come to you, or meet up no problem, cheers.Blanco92 wrote:Hi, are you still offering this? I'm <sometimes> Gatley based. Have VCDS but not VCP...addy73 wrote:Hi, I can offer this service in Stockport using a genuine vag can pro. you will need folding mirrors that fold on the switch, I can then programme them to either unfold on the keyfob, or unfold when you start the car, £30.00 thanks.
sciroccomods
- I drive a: R-Line
If anyone requires Powerfolding mirrors or coding to fold off the keyfob around Manchester then let me know, I use a genuine Vag can pro,
Cheers.
Cheers.
Re: Power mirror fold using the fob ? EDIT -You need Vag Can Pro
@addy73 Any chance you could tell me how to do the folding mirrors on the fob on my car .. i keep getting vag can error saying error entering security mode . so from what ive read on here i need to go into enginerer mode and do it that way ...
any chance you could tell me how to enter security mode on vag can pro please and add the folding mirror function to my keyfob please.
sciroccomods
- I drive a: R-Line
DELETED
DL04LRL
- I drive a: R-Line
@addy73 do you still offer this service .. I am 5 mins away from Stockport and need this in my life
sciroccomods
- I drive a: R-Line
Yes im still doing powerfold mirror installs, cruise control installs, other coding etc, and i live in Stockport.
Ras
Hello, I need help from someone who knows how to code EEPROM for the Gen3 door module.
I watched this video:
And I believe I have the exact same module as shown in the video. This is my module:
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 5K0 959 701 C HW: 5K0 959 701 C
Component: Tuer-SG 009 2119
Coding: 0004278
Shop #: WSC 01357 011 00200
VCID: 326BAFCFAD2F681D85-8066
No fault code found
Tomorrow I’m renting an A+++ ODIS VAS6154 with engineering mode 18.xx and 17.xx, which supposedly can handle EEPROM modification. So I hope the security code will work the same way as in the video.
What i dont understand in video is on some tutorials they target address length in hex B0 and 48 in dec then swap 3 C2 bites to D6, in this tutorial he loaded 189 and 10 then 30 then 40.. Can i only load 189 in dec and 48 in dec to immediately load all bites with C2 that i need to change? Then he skipped write cells. After i change those 3 C2 to D6 i click write cells and then close program and thats it?
D6 is to open mirrors when i open drivers doors right?
Also do i need to code 52 passenger door module?
Thanks in advance!
Coding: 0004278
No fault code found
Thanks in advance!
sciroccomods
- I drive a: R-Line
what a load of faf, where are you ?
sciroccomods
- I drive a: R-Line
Where are youRas wrote: ↑Wed Sep 10, 2025 3:54 pm Hello, I need help from someone who knows how to code EEPROM for the Gen3 door module.
Coding: 0004278
No fault code found
Thanks in advance!
Ras
To far away, Bosnia and Herzegovina
Ras
Guys just quick update on this.
I managed to get it work with OBDEleven. And im not talking about adaptations but Eeprom editing on GEN3 door modules. It can be done with obdeleven and is very simple. Mind blowing.
Sari
Tha'ts really interesting news. I don't suppose you'd care to share how you managed this?
ratkogti
- I drive a: GTS TSI
Hi Ras,
Im from Serbia, also have a 2017 scirocco and have been strugling to code folding mirrors and also this morning got the idea that i could use obd11 eeprom editing to get it to work. I just dont know which addresses and values to edit
I hope that you see this so i can contact u, and possibly help me get this done!
Pozdrav brate, nadam se da ćeš stvarno videti ovo nekad!
