Bagged Scirocco from Finland / / Facelift
Re: Bagged Scirocco from Finland / / Rare Wheels
This build thread is getting more and more interesting:) can't wait to see the facelift xenon's on
- Jimijokela
Comparasion picture of my interior changes. Even though i think the hydro dipped carbon parts look ok, i bought a second set of interior trims and i'll paint them piano black. Simpler the better.
Untitled by Jimi Jokela, on Flickr
Fitting headlights tomorrow..
Untitled by Jimi Jokela, on FlickrFitting headlights tomorrow..
Looks great!
How do you find the feel of new steering wheel?
Is it smaller than the old one?
- Jimijokela
Cant say anything about the size, but it sure does feel and look great.
- Jimijokela
Headlights done. Just minor problem that the leds are flashing when i start the car. I'll try to fix that with some electric components but that will be later. Afterall it was dead easy to do these. I only had to add one repair wire, from bumper drl + signal to headlights port 10. I didnt want the other little light at headlights workin but it's just wire from 12 to 8. I have 2009 car so i didnt even need any coding. Im probably going to unplug the drl's from bumper so they will just work as blinkers for me.
Untitled by Jimi Jokela, on FlickrRe: Bagged Scirocco from Finland / / Facelift headlights
It looks stunning!!
More pics
More pics
Storm trooper rocco
Loving those wheels, prefer those bbs speed lines though.
Rolling in a candy white Facelift Rocco and Rs200 full fat clio
sc cal
badass ride!! got all the componetns to install the headlights also but cat find the headlights ;( where did you buy them? it looks amazing!!
- Jimijokela
Thanks guys. I still havent figured out the led flashing. I think i'll buy 12v regulator and try with that.
Headlights are off ebay and they were complete kit
Love the way this sits!
Salsa Red 2.0 TDI Scirocco
- Jimijokela
Footwell lights DIY here..
Okay so i ordered this set: http://www.bold-sport.com/store/index.p ... uct_id=131" onclick="window.open(this.href);return false;
The instructions on that site are:
Install Info for Front Footwell Light Housing
Golf VI, Jetta VI, scirocco, tiguan
Electrical System Controller (J519)
connect + B50, - Ground
Coding 09 > 07> 42bit add 1
Golf V, Jetta V, Passat/ Passat CC, R36
connect + B7, - Ground
Coding 09 > 07> 2bit add 4
Even though there is a scirocco on the upper info, but i have the old type of BCM so i followed the lower instructions. I actually didn't know which one i had before trying to put the pin in right place.
The bcm is located below the steering wheel, you have to remove 3 torx screws and you can see the bcm, the working position is really awkward, i had my head on the floor and legs up to my seat..
But it's pretty clear where you have to put the wire, on the B connector and there is a number 7. First you have to unlock the connectors and it's done by pressing the red part on the (auf) arrow direction. Now you can take the connector off. Next there is a purple part on the connector you have to pull with screwdriver, just be careful that you dont take all the wires away by accident. The wire came with the right pin so just put it on the slot 7, lock the connector by pressing the purple part down, put it back in the bcm and lock the connectors.
I used clothtape? to wrap wires.. Same stuff what are used around oem wires.
There are already places for the lights, you just have to press the covers off. Then just simply put the units in place. I placed the wire behind and under the radio.. Just had to undo the two big interior pieces on the footwells. Just undo the one screw and pull it down. I found the oem ground point behind the hood opening lever. Do the vagcom coding: 09 > 07 coding> 2bit add 4. Then you can play with the dimming located on 09 > adaptation. I put 50% when the oem is 80% But i think im going to try more values and see what looks the best.
And since all off my interior lights are leds and i had leds for footwell lights already i put them on staight away.
If you have the new type of bcm the right pin is on the B connector and pin 50.
It's always dark in Finland at this time of a year so bad photo but you'll get the point.
Untitled by Jimi Jokela, on FlickrThere are already places for the lights, you just have to press the covers off. Then just simply put the units in place. I placed the wire behind and under the radio.. Just had to undo the two big interior pieces on the footwells. Just undo the one screw and pull it down. I found the oem ground point behind the hood opening lever. Do the vagcom coding: 09 > 07 coding> 2bit add 4. Then you can play with the dimming located on 09 > adaptation. I put 50% when the oem is 80% But i think im going to try more values and see what looks the best.
Hi!!
First I have to say, I really like what you are doing. Keep up the great work!!
You have basically the exact same base as I do, a 2009 one and I have also retrofitted the R led daylights in the bumper.
Now I'd also like to add the facelift headlights, but I would also like to keep the lower led daylights in the bumper, too.
The problem is the blinker, do you think it's possible to modify the facelift headlights so that they have an integrated blinker just like the pre facelift xenon headlights? Imo both led daylights together are just pure awesomeness!
- Jimijokela
You should buy the bumper drl's with blinkers. Thats what i have. My pre-facelift bi xenons didn't have blinkers.
cool303
Looks so stunning!!! Love it all changes you've done
Green Machine
Hello, i was wondering do you still have the standard headlights and how much would you sell them for if your willing to sell?
- Jimijokela
Yes i have them and quite a many have asked them. I cant sell them yet because my lights doesnt adjust yet. I have the afs already but there are so little information how the wiring needs to be done so i dont want to do it yet.
- Jimijokela
I've owned this car for a year now so i decided to do a mod list and few pics from past year.
Starting with:
Interior
Carbon interior trim (going to piano black soon)
Mk7 flatbottom multi-function steering wheel
Rns510 (few problems with unit, will be on soon)
2xracetech digital airpress gauges
Blue cluster needles
Trunk build for air suspension stuff
Footwell lights
All interior lights changed to led
Sound insulation everywhere
Exterior
Full pre-facelift r bodykit
Exhaust to fit the r rear bumper
All windows except windscreen tinted
Rear wiper delete
Facelift r bi-xenon headlights
Tinted rear lights for R look
Black vw emblems
Other badges deleted
Suspension & Wheels
Airlift performance front kit with camber & 30-Level Adjustable Damping (-3.5 degrees of front camber)
Airlift rear bags with cut brackets
Bc racing struts with 30-Level Adjustable Damping
GodSpeed rear camber kit (-5.5 degrees of camber)
Avs-7 control system, smc valves etc..
Work Emitz wheels 10"x19" et 20 on front with 235/35 tires 10.5"x19" et20 with 255/35 tires.
Some painting and polishing done too.
Thats what i can remember.. lol
There can be other mods too but cant remember them.
Then to photos:
Plans!?
Some wrapping, new color scheme for wheels, maybe interior upholstery and some small stuff.
Also i started to build my 1979 scirocco gt full time now.. I'll update my instagram with pictures when something you can see is done! Working with the motor atm.
Starting with:
Interior
Footwell lights
Exterior
Rear wiper delete
Black vw emblems
Suspension & Wheels
Then to photos:
Untitled by Jimi Jokela, on FlickrPlans!?
Gazzagood
Hi mate, how did you code / wire the DRL to stay on with the headlights? I fitted an R bumper with genuine DRL and xenon lights, but when i turn on my headlights the DRL turn off
- Jimijokela
I remember doing some coding with vcds. Cant remember the exact thing i did but there are not that many drl settings so you can just try everything
Maybe "scandinavian drl" or something.
Gazzagood
I tried everything and just cannot get them to work
lol, did you wire them into the sidelight wiring?
