Definitely finishes it off. Let me know how the footrest goes. I will defo buy one if they fit well . cheers
Sent from my LG-D855 using Tapatalk
Scottish Candy White 160 *APR Stage 1*
Re: Scottish Candy White 160 *APR Stage 1*
Fitted the new footrest, but it required a slight modification to the back of the plastic where one of the clips were. nothing major just a wee file down to allow the washer to sit flat. really simple to remove a t20 torx screw and a flat head screwdriver, then a 5mm drill, 3mm allen key, and a 8mm spanner to fit the footrest.
the circle on the left is a funny wee clip, screw in the middle but you need to hold the outside of the head to stop it turning or just give it a pull
once its out the whole footrest just pulls up and out. then just the reverse when fitting.
Pleased with the end result and much cheaper than OSIR one although the rubber doesnt stick through like the pedals.
Hope this helps
Hope this helps
Progress Thread: http://www.sciroccocentral.co.uk/forum/ ... 13&t=17459" onclick="window.open(this.href);return false;
- Irvysan
- I drive a: R-Line
- In: Ultra Violet
Hi mate, I ordered one of these of the back of your post I hope it's as easy as you say. Will need to try and find my file now. CheersDunk04 wrote:Fitted the new footrest, but it required a slight modification to the back of the plastic where one of the clips were. nothing major just a wee file down to allow the washer to sit flat. really simple to remove a t20 torx screw and a flat head screwdriver, then a 5mm drill, 3mm allen key, and a 8mm spanner to fit the footrest.
once its out the whole footrest just pulls up and out. then just the reverse when fitting.![]()
Hope this helps
Sent from my phone
- ddda100
- In: Pyramid Gold
hi fella... aren't those exhausts sweet!
- In: Night Blue
I'm looking to get my lights done by them as they're pretty close to me and the price isn't too bad.
Angel eyes and bi xenons.
You've had them for a while now did they fail on your or anything in this time?
Also mine doesnt have xenons so they would have to fit bi xenon projectors. What's the legal side of this? Will the cops hassle me?
- SKGR
Hello there,
Where did you get the milltek downpipe? is it a decat or sportcats?
It is impossible to find a milltek downpipe with a 200 cell sports cat for the 1.4 twincharged, seems like they stopped making it... :\
thank you!
Cheers,
SKGR
thank you!
Cheers,
SKGR
