ZebrasKneecaps
In: Pure White
Options: Bought 2nd hand, hoping to add some extras on my journey :-)
Post by ZebrasKneecaps »
That'll look mint. Make sure you take some pics mate
Dreamer
Post by Dreamer »
Took advantage of the lockdown and fantastic weather.
Overhauled the front brakes. Full strip down then painted with high temperature anthracite. Finished with acrylic high gloss lacquer.
The rears will be done to match
Dreamer
Post by Dreamer »
Coded my dipped lights so they are not permanently on. Now only side lights as DRL and dipped come on at dusk automatically or manually when selected [emoji16][emoji106]
I used VCDS
Controller 09
Byte 11
Bit 2
Dreamer
Post by Dreamer »
Coded XDS
Fitted LED interior lights through out.
https://www.ebay.co.uk/itm/VW-SCIROCCO- ... 2749.l2649.
No issues what so ever. Good lamps and all correct sizes. Great light out put.
DubSteve68
In: Indium Grey
Options: LEATHER/DUAL ZONE CLIMATE/RLS
Mods:
RNS-510*
CRUISE CONTROL*
REMOTE FOLDING MIRRORS WITH REVERSE DIP*
R-LINE SMOKED/CHERRY REAR CLUSTERS*
SMOKED FRONT INDICATORS*
BCM CODED FOR LED LIGHTING*
DUAL REAR FOGS*
FRONT FOGS AS DRL (PRL OFF, SIDELIGHTS OFF IN DRL CHANNEL)*
Post by DubSteve68 »
Fitted the last set of Osram Premium LEDs to my rear light clusters and coded up with VCP. NO errors, NO resistors, NO hyperflashing. Looks like a modern car again :D
Genuine VCDS and VCP System available in North West - Burnley/Pendle/Ribble Valley/Craven areas. PM me if in need.
Dreamer
Post by Dreamer »
Do you have links to the LEDs and photos please?
DubSteve68
In: Indium Grey
Mods:
RNS-510*
CRUISE CONTROL*
DUAL REAR FOGS*
Dreamer wrote:Do you have links to the LEDs and photos please?
I'll post some action pics later but these are the ones. All bayonet bulbs are Osram LEDriving Premium SL series, stop/tail/fog are P21W and the indicator is PY21W. I'm not going to say these are CANBUS friendly because - as we all know here - bulb monitoring is a function of the BCM, not CANBUS itself. These bulbs WILL throw a dash error without resistors or BCM coding, but if that side of things is taken care of these bulbs are ideal for the job given how they're designed to use the reflector rather than directly projecting light forward. They've also got far heftier heatsinks than you'll find on most other P21W bulbs, should help with longevity.
P21W/BA15S - " onclick="window.open(this.href);return false;
PY21W/BAU15S - " onclick="window.open(this.href);return false;
Cheers, DubSteve
Dreamer
Post by Dreamer »
Replaced the front wishbones with all bushings and new ball joints.
Then replaced the rear trailing arms complete with bushes. Just the lower control arms and camber arms to do, then the whole suspension has been renewed.
Already done the drop links, anti roll bushes and dampers/springs with top mounts
Full four wheel alignment to follow. Feels 100% better already. It wasn't bad but I intend to keep the car for a while and wanted a like new experience.Its well worth doing especially with the 40% discount at ECP. I used lemforder parts, which I have used for years across Mercedes, Audi and BMW with no issues.
MackemVR6
In: Shadow Blue
Post by MackemVR6 »
Expensive day, 40k service, air con service, brake fluid change, new EBC discs and yellow stuff pads, VWR springs and Revo stage 1 fitted. Totally worth it :D
Dreamer
Post by Dreamer »
MackemVR6 wrote:Expensive day, 40k service, air con service, brake fluid change, new EBC discs and yellow stuff pads, VWR springs and Revo stage 1 fitted. Totally worth it :D
Did you do a lot of that yourself bar the Air con and Revo stage 1? That’s a big bill if not but like you said. It’s worth it[emoji106]
MackemVR6
In: Shadow Blue
Post by MackemVR6 »
All done at Vagtech :yes:
Andy b
In: Night Blue
Options: Black 18" interlagos wheels
Truffle leather
H&R lowering springs, 30mm drop
VW sill kick plates
Alive tuning stage 1 (248hp/322nm)
Helix organic clutch
R8 coil packs
Post by Andy b »
Got the da out and gave the car a good polish and sealant
Andy b
In: Night Blue
Truffle leather
VW sill kick plates
R8 coil packs
Post by Andy b »
Andy b
In: Night Blue
Truffle leather
VW sill kick plates
R8 coil packs
Post by Andy b »
sciroccomods
Options: Mk8 R heated wheel,
Sequential animated Bi-xenons,
Sequential animated rear lights
Electric cooling/massage/memory Leather seats,
auto dimming power fold mirrors,
virtual cluster,
Dynaudio,
panoramic roof,
Dcc,
Direct tpms,
Blindspot assist,
Acc,
Lane/Sign/high beam assist,
Post by sciroccomods »
Added leds to my cup holder and 3d printed a scirocco divider
added leds to my external door handles, i cant upload any pics tho.
I offer Power fold mirrors installs, Cruise control installs, Coding, mirror folding on keyfob etc. i'm in Stockport,Manchester
alexthegrumpyone
Post by alexthegrumpyone »
Done a video on front DRL unit upgrade to the one with dynamic indicator and I am well happy with it!
3Triple7
I drive a: 1.4 TSI 122/125
Post by 3Triple7 »
alexthegrumpyone wrote:Done a video on front DRL unit upgrade to the one with dynamic indicator and I am well happy with it!
Ohh those look really smart pal!
3Triple7
Post by 3Triple7 »
Today I changed batt in my remote fob and managed to 'un sync' it. I've tried every manual reprogram way poss but no joy :? :?
MackemVR6
In: Shadow Blue
Post by MackemVR6 »
I had cruise control retro-fitted, very happy with it.
AMorrison
In: Night Blue
Options: Winter pack
Post by AMorrison »
I managed a turbo delete with the added benefit of oil ejection if that counts?
Can't wait to see how much needs sorted
Sent from my SM-G973F using Tapatalk
