ThanksMackemVR6 wrote:It's a complete assembly, not the ashtray with a different insert. Search the web for 5K0857961A 9B9 to see what I mean. I had to buy the surround, lid cover and rubber mat separately. Got them from Deutsche Parts, cheaper than VW and genuine parts.
Good luck with the covered cup holder, it's a bit of a pain but worth it.
blz-8027
- In: Night Blue
blz-8027
- In: Night Blue
MackemVR6
- In: Shadow Blue
Yup, it's an awkward little bugger but satisfying when it's all back together, scratch free. Good work mate
blz-8027
- In: Night Blue
at work all day today ,so it has to wait till wednesdayMackemVR6 wrote:Yup, it's an awkward little bugger but satisfying when it's all back together, scratch free. Good work mate
so bought one of these as well to replace the Media input stuff as it doesnt get used
https://www.ebay.co.uk/itm/Interior-Cen ... SwXoJbSIin" onclick="window.open(this.href);return false;
nathanial rabbitt
- In: Silver Leaf
got new brake calipers, now they are race red, also tinted the rear lights and debadged it
blz-8027
- In: Night Blue
All back together ,apart from the covered ashtry that is being modded
MackemVR6
- In: Shadow Blue
Nicely done! What are you doing with the ashtray?
blz-8027
- In: Night Blue
ThanksMackemVR6 wrote:Nicely done! What are you doing with the ashtray?
Hoping to get a box made using a 3d printer ,to replace the ashtray insert ,
so its the same as the covered storage version
P:S
Do you know how the sides of the DSG gearlever are held on ,one side is loose on mine ,but wont clip back on
MackemVR6
- In: Shadow Blue
Sorry mate, mine is a manual. Is it the plastic surround that's loose or the chrome bit? The plastic part has a clip, you may want to pop it out again to make sure it hasn't broken.blz-8027 wrote:ThanksMackemVR6 wrote:Nicely done! What are you doing with the ashtray?
P:S
Delbert
- I drive a: R-Line
Took it into work and serviced it and found the nearside front shockers leaking,,, not overly impressed for a 3.5 year old car with 25k on the clock
MackemVR6
- In: Shadow Blue
Had the timing chain tensioner, chain, guides etc replaced for peace of mind. Not a cheap job but cheaper than an engine rebuild.
designer1971
swapped rear wheels to front as worn on inside and humming like worn bearing!humming now at front so defo tooth saw tyre wear!
Happy in one way!
Happy in one way!
designer1971
swapped wheels from rear to front cos of tooth saw rumble
L_Faith
Today I painted the brake calipers and debadged [emoji38]
Only had my Scirocco for a month so there's more work to be done!
Sent from my CLT-L09 using Tapatalk
Tenko73
Sachs dual mass flywheel (eight crank bolt holes)
- 30% uprated pressure plate (not heavy under-foot)
- carbon Kevlar lined clutch driven plate (nice and smooth but precise engagement)
- a concentric slave cylinder release bearing
- a set of flywheel retaining bolts
- a set of clutch bolts
Ready for Saturday's re-map.
Misanthropes need people; without a steady supply, the misanthrope cannot fully apply his art.
Tenko73
Had the the pipe replaced that was causing my fault code P0101. The mechaninc damaged it fitting the clutch! He reckons it's all good. Gonna have to give it some beans tonight to make sure.
All ready for AGChiptuning to remap tomorrow.
Tenko73
Stage 1 done. Thanks to Alex at AGChiptuning for that and for letting me know that I have a healthy engine. Would highly recommend him for your tuning needs.
Sent from my TA-1033 using Tapatalk
Tenko73
Please disregard the above. I had the car dyno'd and i got 235bhp as the fuel is running rich. I now have to have the car put back to stock to have the fuelling adjusted. Hopefully its not the Lambda sensor. If they can adjust the fuelling and reinstate the remap and it hits 250 i'll be happy but, it has still cost me for a dyno and will cost me for the adjustments. All in all, an expensive remap. You live and learn.
In a nutshell don't get your car mapped by AGChiptuning.
Tenko73
This was the Dyno run after the AGChiptuning remap
