blz-8027
- In: Night Blue
Fitted some shiney bits
Snikers10
- In: Night Blue
Debadged the rear - yes it's just the 1.4 but I promise I only did it because I think it looks better [emoji849]
Sent from my Pixel 2 using Tapatalk
- vladandrei51
- In: Night Blue
Those tail lights are sweet, where did you buy those from?
cristispd
Those are the OEM Facelift tail lights.
- spuf
Getting ready for Passat aluminium spindles + alu lower arms, and Powerdiscs front&rear.
More to come
More to come
cuprajake
Picked my scirocco up, swapped for mr leon fr 170 tdi
So full machine polish, wax and interior valet
- 3t3p
what kind of a garage is that with all that space??!
- spuf
@3t3p it's a beautiful Vw Garage in which I work.
As of now, I started to work on a diff. swap with a Wavetrac LSD. Wish me luck
- 3t3p
nice, putting in an LSD!
where is your garage then? is it the batcave?
whats with that weird narrow rear tyre?
Silverback
- I drive a: GTS TSI
Enabled a number of VCDS functions, most important of which was XDS. Also changed some lighting options as well as headlight wash frequency for the winter.
Not entirely sure if they are all working as its a gash OBD lead but we'll see. The XDS enabling was worth the £40 quid tbh.
- spuf
You can call it the Batcave, but it's not located in the U.K. I live and work in Bucharest, Romania.3t3p wrote:nice, putting in an LSD!
The weird narrow tyre is just part of the winter setup that I have... Steel 16" inch wheels. Narrow, but excelent on fresh snow/ice.
Rg_
I need to do this!I have a spare MK6 GTI wheel without buttons but my scirocco has MFSW.ethan_rose wrote:Followed up with RCD330+ head unit installed, very happy with the outcome http://www.sciroccocentral.co.uk/forum/ ... 02#p205502ethan_rose wrote:Installed MFSW buttons! Already had the high line steering wheel controller in place so very easy.
Will my MK6 wheel have the plugs behind the airbag?
- Mando
ok technically not "Today" (it was Sunday).
Finally got round to replacing all 4 main speakers with JBL 165mm 2-way jobs, spliced in stock tweeters front/rear (man what a task it is getting to the rears) fitted CS stalk adaptor so i can use my Pioneer Dab double din and steering controls and whacked in a JBL 12" sub cab and GX series mono sub amp in boot (pro wired 8 gauge) post 780a battery upgrade.
Sounds immense.
Sounds immense.
Why does comfort mode feel like, wearing shoes 2 sizes too big?
MackemVR6
- In: Shadow Blue
Had OEM Bluetooth Module & Foam fitted along with RNS 510 DAB. I know I could have got a more up to date system but I wanted it period correct (it's a 2010 model). Fitted rear cup holder and tomorrow having a few dents from previous owner removed. Washed it too.
MackemVR6
- In: Shadow Blue
Fitted Scirocco R pedals, look great too.
MackemVR6
- In: Shadow Blue
Fitted the covered cup holder in the centre console today. What a ballache, but it's in now and is much better than the original open cup holder.
MackemVR6
- In: Shadow Blue
Had powerflex poly bushes fitted to front wishbones & rear lower springs, replaced sidelight bulbs. Noticed that one sidelight has condensation, is there a fix for this or is it a case of buying a new one?
MackemVR6
- In: Shadow Blue
Fitted a covered stowage compartment as I didn't want to fit the ashtray. The hardest part was removing the white clip that holds the wiring to the underside of the stowage moulding. Then I realised that I forgot to cut a hole in the bulb holder to allow the compartment to be illuminated so had to take it out again
blz-8027
- In: Night Blue
where did you get the insert from ? ive fitted the lid bit , but dont have the insert,also got the covered cup holder to fit stillMackemVR6 wrote:Fitted a covered stowage compartment as I didn't want to fit the ashtray. The hardest part was removing the white clip that holds the wiring to the underside of the stowage moulding. The I realised that I forgot to cut a hole in the bulb holder to allow the compartment to be illuminated so had to take it out again
MackemVR6
- In: Shadow Blue
It's a complete assembly, not the ashtray with a different insert. Search the web for 5K0857961A 9B9 to see what I mean. I had to buy the surround, lid cover and rubber mat separately. Got them from Deutsche Parts, cheaper than VW and genuine parts.
Good luck with the covered cup holder, it's a bit of a pain but worth it.
