So, even in the off position, essentially my headlights are on? I can see why all the discussion on here about getting these DRLs turned off! Cheers.Cuprabob wrote:On your car the dipped beams are the DRLs, hence why you cannot switch them off in any setting other than sidelights. I appreciate it can be confusing but it's normal.
The auto function is really redundant and if you want to check the main beam turn the switch fully clockwise to manually switch your lights on and then check operation. When the lights are on in every other setting they are effectively DRLs and may not allow main beam operation.
Sidelights are the 2 small lights next to indicators.
Bollocks.martdy wrote:The light sensor is directly underneath the bottom left hand corner of the Parrot(top right of RCD510). It 's not very big - about the size of a pin head. So yes in that picture it is covering the sensor.
Okay, so, Orange engineer comes back Weds. If I get him to move it to the opposite side, will that be okay? Or will there be some other teeny-tiny yet crucial component to cover up...
(Who puts a sensor there anyway? What's wrong with on the windscreen by the rear view mirror? Sheesh!)
