now modified with dump valve, boost gauge in custom made vent, "gt" steering wheel badge, carbon fibre badges, rs4 wheels, lowered 35mm, private plate S18OCO, custom de-cat and cat back exhaust with quad tips, air filter behind fog lamp heat wrapped, customised front bumper grills painted gloss black, customised rear bumper smoothed and lower spoiler painted gloss black, mouldings and mirrors sprayed in gloss black, gloss black roof and rear spoiler, colour coded dash trims, door trims, centre console trims and rear seat trims, led fog light bulbs, s3 intercooler, audi a4 "S line" gear knob, newspeed hi-flow throttle body pipe, newspeed hi-flow turbo pipe, uprated dog mount bush, front to back and side to side quickshift, 20mm front spacers
its not a dump valve as such as theres one thats standard from factory anyway thats electronic, its a spacer that you get from forge, it does make the "chirping" noise if you change gear early, but if you leave it all the way to top revs then its like a normal one.
and it sounds even better now it has an exhaust system on it
the wheels are 19", and now one is chipped, because a badger tried to get me down a lane so had to go up a little verge, and obviously theres no tyre protecting the rear wheels so its chipped
Looks great, its nice to see some variation on the standard Rocco so soon after launch. This might sound like a daft question to some but why have you had a dump valve fitted. Don't all turbo engines have one of these anyway and if so why change it, is a perfomance enhancing thing?
Ernie wrote:Looks great, its nice to see some variation on the standard Rocco so soon after launch. This might sound like a daft question to some but why have you had a dump valve fitted. Don't all turbo engines have one of these anyway and if so why change it, is a perfomance enhancing thing?
most newer cars have a dump valve fitted as standard now, but you cannot hear them, i wanted it so you can hear it, it helps release pressure basically and sounds better (in my oppinion anyway).
i also have an air filter added, it gives off more of a "chattering" sound from the dump valve, i just need to make a heat shield for it so it can breather coller air better
heres a pic of the air filter and heat shield, a new one will be on its way soon then a better heat shield/box will be made, but this is it for now
and the de-cat is done now, can defo feel the difference it has made, im booked in a week today for a company to "read" my ecu, then a map will be done for it, i will let you know what happens
Hi, I'm Spanish, and i like to know where to buy this black " W " in carbon.
There are pictures of your car at the Spanish club scirocco, is beautiful!
