Latest Scirocco R (and R-Line) parts List
Re: Latest Scirocco R (and R-Line) parts List
Are the front bodywork wings a different part no?
They look like they bulge out slightly more on the wheel arch but may just be an illusion caused by the R front bumper
I don't know which number is for the black leather head rests of Scirocco R. Anyone can tell?
- proof
What number at black panel for new climate? and Overlays on thresholds R-line? Anyone can tell? Thanks!
- detinU
So what was the verdict on the R led lights?
I have ordered a 1.4 TSI DSG with xenon lights, can I swap in led lights?
Cheers![Smile :)](./images/smilies/smile.gif)
take your pick on topics it has previously been discussed in detinU
http://www.sciroccocentral.co.uk/forum/ ... =39&t=4586" onclick="window.open(this.href);return false;
http://www.sciroccocentral.co.uk/forum/ ... =39&t=4763" onclick="window.open(this.href);return false;
http://www.sciroccocentral.co.uk/forum/ ... =39&t=4415" onclick="window.open(this.href);return false;
http://www.sciroccocentral.co.uk/forum/ ... =39&t=4036" onclick="window.open(this.href);return false;
& see http://www.sciroccocentral.co.uk/forum/ ... drl#p37044" onclick="window.open(this.href);return false; for a recommendation on an alternative source for front LED lights for the standard bumper
welcome by the way, & next time
![BigThumb :bigthumb:](./images/smilies/thumb3d.gif)
![Try Search :trysearch:](./images/smilies/trysearch.gif)
Sill plate P/N
Evening all,
Would someone with an up to date ETKA be able to provide the P/N for the drivers side sill protector please (R specific)?
Luke
Luke
Reason: A full list exists. :)
http://www.sciroccocentral.co.uk/forum/ ... ing#p32556" onclick="window.open(this.href);return false;
small question.
can we do a direct swap of a R headlights with the GT? my GT comes with xenon.
The R headlight is different to the standard xenon unit. Your basic issues are going to indicators and DRL's.
your different means?b0rk wrote:The R headlight is different to the standard xenon unit. Your basic issues are going to indicators and DRL's.
perhaps i should post elsewhere for this.
thanks~!
anyone knows the part number for the dust cover (rubber like) thing for the rear r brake pistons?
both my rear got torn somehow....
Okay I'll be more clear the units are not a direct swap. The R unit has the xenon beam as in the outer position and the indicator in the inner location. The standard Xenon unit as the sidelight / DRL in the inner location you'll need to sort out the wiring loom to activate the correct elements.elxin wrote:your different means?b0rk wrote:The R headlight is different to the standard xenon unit. Your basic issues are going to indicators and DRL's.
In answer to your other Q the rear dust seal is 1J0 698 671 to suit calliper 8J0 615 423 E / 8J0 615 424 E
thank you so much for the dust seal part number.b0rk wrote:Okay I'll be more clear the units are not a direct swap. The R unit has the xenon beam as in the outer position and the indicator in the inner location. The standard Xenon unit as the sidelight / DRL in the inner location you'll need to sort out the wiring loom to activate the correct elements.elxin wrote:your different means?b0rk wrote:The R headlight is different to the standard xenon unit. Your basic issues are going to indicators and DRL's.
I've a bi-xenon headlights with the inner location as DRL and static cornering light. so in short, apart from wiring and maybe some coding-- the R headlights are a direct fitment in terms of the bumper / bracketing and etc?
ETKA indicates the attachment points are common.
thanks...b0rk wrote:ETKA indicates the attachment points are common.
shall experiment with it and keep you guys updated
