Fuel/Distance Remaining, how low can it go?
RW1
Legend
Hi from Sunny Stopfordia
Re: Fuel tank capacity
Post by RW1 »
Here you go...........
Fuel Tank Capacity
1 - How Low?
2 - How Low?
The highest quantity of fuel I've put in one filling is 54.12 litres.
Then sometimes on a rainy Sunday afternoon when the garden gets too wet..... a doodle. Apart from the two amber "low" segments on the dial, all readings relate to the major tick marks. Values are in litres. The top 6 litres of the fuel tank saturate the pointer on FULL.
Also, there is a tank characteristic setting in VCDS - Adaption in the Instruments Controller Module 17. Not investigated it yet or know whether it makes adjustments on the Scirocco.
29 Oct'09 at dealers
Driving 4th Nov. Sorted!
Crossbone
I drive a: 1.4 TSI 122/125
Options: Sports package with black alcantara leather seats, metal pedals, tinted rear windows, 18' Interlagos, multi-function steering wheel, rcd 510, 2 zone climatronic, armrest, premium mats, winter package, lights and mirrors package, aluminum foot rest, covered cup holder.
Post by Crossbone »
There's something strange that I noticed. As RW1 said, I also calculated that when you only have the 2 amber segments left on the dial and the light flashes there about 7 litres of fuel in the tank. This means that if you drive nice and steady, you can get a 6, maybe a 6,5l/100km from a 1,4tsi. So, in theory, you can drive 100km/60 miles more from the time you have 2 segments left. BUT, in real life, after driving very gently, after about 50-60km, the needle is down to empty.
So what does this mean? Simple. You have about 2,5-3 litres left in your tank but the needle says it's empty and the range is down to 0. VW have conceived a scheme to play with your mind and force you to refill by making the needle go down faster. I have managed to keep very 'cool' on 2 occasions and go further with the range on 0. The result was that 55,19 and 55,7 litres got inside(the last one was when I got the car from the dealer's).
The point of the story is that you can keep on driving for about 50-60km from the time the range shows 0 and the needle has hit the floor. Of course, you need nerves of steel. :D
ps: I know someone who has managed a 56,4 and a 57,1 refill.
Crossbone
Re: Fuel/Distance Remaining, how low can it go?
Post by Crossbone »
You can go for about 50-60km from the moment the range shows 0 and the needle is all the way down(tested by me), without the engine stoping. I tried this a couple of times and after that I managed to squeez 55,19 and 55,7 litres in the tank.
I have a friend with a diesel Scirocco and he took it to 57.
Grampa
Options: Panoramic Sun Roof, Piano Black interior, black 19" wheels
Post by Grampa »
skippy wrote:o yes there is every chance it will run on past zero but I don't like to chance it!
Same here - I ran my previous Astra to 5 miles - left it parked on my drive which is quite a steep slope, and it obviously was enough of a gradient to remove fuel from the outlet on the tank as it wouldn't start later that day. Don't know if a Scirocco is the same, but adding petrol wasn't enough to get it going again - I had to get the AA man out to use his laptop to tell the engine it had fuel again and was OK to start.
richwill607
Options: Reversing Sensors,
Premium Sill Guards,
VW Touch Blue Tooth Kit.
Ordered: 21st Jan 2010
Build Week: 10
Collected: 29th Mar 2010
Smiling ever since
Post by richwill607 »
peter.vw wrote:
if your running a TDI then you dont have the problem.
Don't run out of Diesel as it can be a very expensive problem!! It would usually involve a tow truck to a dealer to have the system purged of air which sometimes involves having to dismantle all of the injectors (Depending on Engine age and manufacture etc, the newer the engine the more work and cost!). Alternatively if you decide to just refill with Diesel then you run the very high risk of damaging the injectors and having to replace them all! Nice!!
It is a far bigger problem running out of Diesel than petrol, so not quite sure what you're on about peter.vw!!
Anyone still want to see how far their car goes after the 0 indication! :shrug:
Rocc on!
the_tyce
Options: Dynaudio
Fuel tank capacity
Post by the_tyce »
I got to range 0 miles and did a further 26 miles, all beit on the motorway at 70mph
maisbitt
Post by maisbitt »
Closest I ever got was 30 miles over the "0 miles", with a 53.9l fill up. Is the 7l reserve part of the 55l, or is it 55l + 7l capacity?
2011-2013 - Rising Blue 170GT
2009-2011 - Pewter Roc 140GT
robrain
Options: DVD/Dynaudio, Park sensors, Cruise, Electric mirrors, Bluetooth (handsfree)
Post by robrain »
Off-topic, but best I managed was 32 miles in my old BMW, with the aircon off, radio off, windows shut, helium right-foot, heart in mouth and AA card/mobile at the ready. Probably had 1.5l left.
Ordered 14/8/2010. Scheduled BW4 2011. In dealer Feb 4th 2011. Driving Feb 11th 2011
Crossbone
Post by Crossbone »
maisbitt wrote:Closest I ever got was 30 miles over the "0 miles", with a 53.9l fill up. Is the 7l reserve part of the 55l, or is it 55l + 7l capacity?
It's 48+7=55litres.
micke_011
Options: Euro + Sports packages, RCD510, 2 Zone Clima
Post by micke_011 »
Oh..I read that it was 50 ltrs..so then it wasn't even close to empty when I managed to put int 48,95 litres the other day. Good to know!
Candy White 1.4 TSI 160 - DSG, ACC, 18" Interlagos (Euro Premium&Sport packs), Alu Door Sills, Current VCDS Mods Needle Sweep, Cornering Fog Lights, Alarm Chirp, Emergency Break Warning, Dension Gateway 5, sort of..
ZephyR
Post by ZephyR »
Apart from the risks of expensive damage to your car, why put yourself thru all the hassle of hitching a lift to the nearest garage and back or waiting hours for recovery ?
Keep it filled up.
Simon_T
Options: DVD SATNAV
DYNA AUDIO 300 WATT SYSTEM UPGRADE
CRUISE CONTROL
BURY BLUETOOTH PREPARATION
ROOF MOUNTED BARS AND CYCLE CARRIER
FLOOR MATS
BOOT LINER
3 YEARS SERVICING
Post by Simon_T »
i had a 2.0 golf gt tdi 140 ps and when the light came on i could easily go between 35 and 40 miles at 58 to 60 mph if thats anything to go by.
fun meter
Options: MY12, 19" wheels, Leather, RNS510, Cruise, Bluetooth, Parking Sensors, Folding Mirrors, Premium mats, MDI...
Post by fun meter »
On a couple of occasions I've been within 5-10mile range, and usually find I fill up with just under 50 litres.
The computer takes time to adjust to your driving style though.
skippy
Moderator
Post by skippy »
I don't see why anyone would want to run the risk with this exercise, as has already been suggested, running out is mighty inconvenient as well as potentially causing expensive damage. :shake:
Malcolm
Options: Satnav
Leather
Reversing Sensors
Folding Mirrors
Cruise control
Carkit
CD Changer (Dumb Choice!)
K&N Filter Replacement
Pentagon Supaglass
Team Dynamics Pro Race 1.3 19" Matt Black
Post by Malcolm »
Remembeer Clarkson and co. ? They ran 30-40miles on fuel in reserve and pipes etc when they did their brim to cap and see who got the furthest........ I've done 10miles on 0 but then unfairly brimmed it and got another 9ouple litres after the pump clicked off.
http://www.chemtec.co.uk" onclick="window.open(this.href);return false;
Karcher-Center-Chemtec for all your Karcher Cleaning Equipment Needs!
0845-890 3600 #1
Searchin4aRoc
In: Sumatra
Options: Truffle Leather / Bi-Zenons / Pano-roof / Rear Parking Sensors / Cruise Control
Post by Searchin4aRoc »
richwill607 wrote:Anyone still want to see how far their car goes after the 0 indication! :shrug:
Count me OUT of this experiment immediately :detect:
davidr86
Tank size
Post by davidr86 »
How big is the tank in a rocco ? Reason I ask is to work out how much it's gonna cost me to fill it
David
rococco
Re: Tank size
Post by rococco »
55 litres.
Shaun
Re: Tank size
Post by Shaun »
Mine was nearly empty today and it cost me £65 !!!
Rob
In: Salsa Red
Options: Scirocco's gone!
Post by Rob »
£72 for me yesterday!! As for the how many miles until you run out......... Where's matt? :d he ran out last week :p
