Scirocco AWD ---- DONE
tanaseav
Re: Scirocco AWD ---- DONE
Post by tanaseav »
The 4 studs/bolts (sorry, but i am not a native English speaker) are for holding the frame/support in the picture....so it's ok with those welded there.
tanaseav
Post by tanaseav »
kentech wrote:Some guys here in Finland have been working on a Scirocco R AWD project for some time now and have now completed the car and all the paperwork to make it road-legal. I understand they're going to do a write-up about the project in English later, but for now some pictures and text in Finnish. They're still updating the forum thread about how they realised the project check back later and there will be more I guess.
Funnily the car they have modded is one that I actually went for a testdrive in while it was for sale at a dealer some 2.5 years ago.
http://www.ffp.fi/bb/viewtopic.php?p=997690" onclick="window.open(this.href);return false;
On Facebook: https://www.facebook.com/pajallecom/?fref=ts" onclick="window.open(this.href);return false;
Video: " onclick="window.open(this.href);return false;
I know about the Finland guy, he had a whole spare car, a Golf R,
He did a very smart job with swapping the ECU and dashboard with the Golf.
His car is a great Scirocco R now.
dimexi
Options: Parking Sensors
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Windows close via rain sensor
Other Mods:
Metal Pedals
Self installed Cruise Control
RNS510
Stage 1 Bluefin
Post by dimexi »
tanaseav wrote:
dimexi wrote:Wow!!! This is proper crazy stuff, wouldn't even dream of doing it to my car; not even by a professional.
Question: You said you have "welded" some bolts in place? Isn't that a structural issue?! In that a bolt (when done up with a nut) is stronger than a weld - so you have now downgraded the bolts strength to that of a weld (weakest link and all that).... Or is this a high strength weld?
There are two places i welded:
1. The middle support element for the cardan-shaft has to be bolted to the car. The car does not have the 4 studs/bolts in place. Here you have two options: 1. Bore 4 holes in the underbody of the car and weld 4 studs. 2 Bore 4 holes and use 4 rivet-nuts. It's not a problem of strength because the middle support frame has a pretty soft rubber bushing inside.
2. i have to weld 3 studs/bolts to the floor-pan to fix the fuel-tank. they are 5 mm studs, not much strength needed :)
ahha!!! Brilliant, that makes sense now :D - It's a big big project!! I bet you love your car even more now ;)
atanase
In: Silver Leaf
Options: none
Post by atanase »
well, there is an ABS error i cannot shake, i might have to also change the engine ECU as the guy in Finland did....but don't want to yet....i still have a few more things to try...
roc82
Post by roc82 »
Hey mate, any news on the project? How is the 4wd holding up? :)
atanase
In: Silver Leaf
Options: none
Post by atanase »
Hello all,
After lots of time, and lots of money spent ...i finallly fixed the damn ABS problem generated because of the awd conversion.
Now everything works great!
P.S: will insert more power in a month or so :D
roc82
Post by roc82 »
Nice to hear that! :D
Can you please send me via PM message where did you make the AWD conversion ? And a estimate cost?
Thanks! :)
RJohnson
Post by RJohnson »
Is anyone in the UK doing this ? would like to get in touch if you are, I am in S Yorks
Paradox1
Post by Paradox1 »
Im not going to lie, Ive been thinking about it........
I
atanase
In: Silver Leaf
Options: none
Post by atanase »
@roc82 i sent you a PM.
if you want to do it, you need some money, some patience and determination...:)
Gather the parts in a few months (it took me six months to gather everything :))) ) ...cross your fingers, pray to god. and start cutting with the angle-grinder :)))
After the first cut, when you see the sparks flying, you know you're royally fucked :))))
mcbailey89
Post by mcbailey89 »
Christ!!! :hyper: :yes:
roc82
Post by roc82 »
atanase wrote:@roc82 i sent you a PM.
:clap: :clap: I guess i will not go further
atanase
In: Silver Leaf
Options: none
Post by atanase »
it's a lot of work, a lot of teeth grinding, a lot of fun but the result it's totally worth it :)
Mostic
In: Oryx White
Options: Let's wait until I start the mods :)
Post by Mostic »
atanase wrote:I changed the following:
4. the fuel tank was a mess because i could not find one that fitted so i bought a fuel tank complete from Audi TT S 8J 2012 and then i cut the neck from my tank and welded it with plastic on the audi tank
I need your help, I am in the middle of same project and I don’t know how to weld the fuel tank and which material I should use to weld the fuel tank? Can you guide me on that?
Scirocco R Build! (Fun, Tough & Cost)
http://www.sciroccocentral.co.uk/forum/ ... 13&t=21372" onclick="window.open(this.href);return false;
MKV Build!
http://www.golfmkv.com/forums/showthread.php?t=195173" onclick="window.open(this.href);return false;
Cthuluawaits
Options: Stage 2
Post by Cthuluawaits »
Where can I find the documentation on wiring in the second lift pump? Tia
