Black Scirocco R
Re: Black Scirocco R
Like it a lot!
Just installed my new VWR intake this weekend. Plus software stage 2
Next I will get a TTS engine cover I guess
Where did you get that cup holder cover from?defuze wrote:Finally changed my middleconsole for some more fancyness
- Maisonian
The best option with these cup holders is to buy them from a breakers; an OEM part will set you back about £40-50.
HOWEVER, they're a total pain to fit! Expect to take most of the central console and arm rest off to mount it as the screws are actually located underneath the moulded plastic.
The thread r.e. fitting these can be found at http://www.sciroccocentral.co.uk/forum/ ... =38&t=1393" onclick="window.open(this.href);return false;.
Reading around the subject, I managed to get the job done c. 2h by taking off the rear arm rest, then dissasembling the centre console. It'll allow you the easiest access to the screws you need to take out in the right order, and avoids scratching any of the soft moulded plastic while doing 'the handbreak shuffle' to get to those two golden screws holding the cup holder in!
Scirocco R - Converting Petrol into Fun via the Wallet.
http://www.sciroccocentral.co.uk/forum/ ... 13&t=22769" onclick="window.open(this.href);return false;
Absolutely, this little console is a pain in the a**s. It's kinda alot work but in the end it looks pretty fancy though
- Phil
- In: Night Blue
Woah!! You really went to town when getting yours out! In all honesty, I didn't touch the arm rest at all when swapping mine over, was able to wiggle the plastic around the cup holder up enough to get under it for the screws. Well worth it though
Phil
Danm, that's pretty nice if that worked for you I just followed a little guide, just to make sure I wont brake anythingPhil wrote:Woah!! You really went to town when getting yours out! In all honesty, I didn't touch the arm rest at all when swapping mine over, was able to wiggle the plastic around the cup holder up enough to get under it for the screws. Well worth it though
If you take the rear lettering off the boot lid it would look great in my opinion
Nice build!
May I ask what have you done with your OEM exhaust?
- Icedog
Nice rocco!
But have you noticed that you have 4 LEFT sided rims? Those wheels have a left and right side since they are supposed to poke inwards in their driving direction? Just a hint, see this picture and you might understand me
Yes I know that The Vossen Wheels aren't like that but they are more expensive. Anyways most of the people wont recognize that I guess but every detail counts I know^^
