Sat Nav Update
dimexi
Options: Parking Sensors
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Windows close via rain sensor
Other Mods:
Metal Pedals
Self installed Cruise Control
RNS510
Stage 1 Bluefin
Re: Sat Nav Update
Post by dimexi »
Ryy wrote:I have a MY2010, 59 plate and still cannot get into that menu that shows you what unit you have.
Any ideas?!
Even from the boot sticker? Maybe I can get it from that? Again - any ideas?
I miss RW1 for his knowledge :(
Activate through VCDS, otherwise, the Video In Motion hack on the internet seems to be able to activate the secret menu. What exactly do you want to find out?! The firmware?
If you have no VCDS, and don't want to install the VIM - best thing is to pull the unit out and read the label on it, it gives a software/hardware version.
Note: VIM (Video In Motion) is a hack/software edit that someone has made for RNS510 units, to be able to continue playing DVDs when the vehicle is in motion. See here
dimexi
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Other Mods:
Metal Pedals
RNS510
Stage 1 Bluefin
Re: Sat Nav Update
Post by dimexi »
chelspeed wrote:OK another £20 on 5 off DVD -R DL discs. Burnt one again using Nero and .......... "DVD error" again. B*******ks. Any other suggestions as to what I might be doing wrong?
Now spent £40 and could have bought a disc for £29.99 off the original link. If I find out what's wrong then I will still have 3 more discs left for the next upgrades so still just about in pocket.
Try using IMGBurn instead of Nero, and make sure you verify the disc when it's burnt (this option is selected by default)
