Scirocco 1.4 TSI from Singapore
Mishaw
In: Dark Oak
Options: Aluminium pedals, Osram Nightbreaker Plus, 19" Lugano with Nokian zLine, Stage1 215BHP/290NM, black interior, VAG-COM mods, R-line front bumper, R-line rear lights, RCD510, Automatic climatronic, KW suspension -20mm, TTS intercooler.
Looking forward: KW Street Comfort coilover.
Re: Scirocco 1.4 TSI from Singapore
Post by Mishaw »
xiaohong: And do you have the stock clutch? And stock gearbox? :O How much Nm you've got? And which hybrid turbo you used? Is it LOBA?
VW Scirocco CZ/SK founder....Join us on Facebook.
xiaohong
Post by xiaohong »
Yes its stock clutch with stock dsg map. Didnt quite like the feel.of the dsg tune as it revs higher before changing gear and slightly quicker in shifts with red line limit at 7100rpm. I have approx on crank abt 385nm or so of torque.
Just too add, its on a wmi kit as well.
For the hybrid, its a custom spec which i wanted in billet wheel matching the k04 cartridge with uprated seals etc.
The trouble abt the gtx turbo is that i will have to do a custom manifold for it and its pretty troublesome
xiaohong
Post by xiaohong »
WMI installed which i forgot to post in my earlier pictures..
[attachment=-1]uploadfromtaptalk1392346843838.jpg[/attachment]
xiaohong
Post by xiaohong »
OEM feel of CAN details..
[attachment=-1]uploadfromtaptalk1392437206495.jpg[/attachment]
xiaohong
Post by xiaohong »
Sorry for the OT.....sharing my other car :)
700hp on a HKS3037s
[attachment=-1]uploadfromtaptalk1392526809350.jpg[/attachment]
xiaohong
Post by xiaohong »
xiaohong wrote:Sorry for the OT.....sharing my other car :)
700hp on a HKS3037s
Custom spec
PE 1000cc injectors
PE head gaskets
HKS 3037s spl turbo
HKS Mushroom Pod
HKS M40i spark plugs
HKS Hypermax II coils
Okada coils
Carbonetics triple plate carbon clutch
Carbon driveshafts
Battery relocated to rear trunk
EJ20 stroked to 2.5l. Fully closed deck with re-sleeve
Wiseco forged pistons & con rods
Billet crankshaft
Mines FMIC
Samco Blue connecting hoses
Jun Stage 3 quad cams
PPG dogbox with straight cuts and final drive
Brembos 4 pots front and singke pot rear
Alutec full struts
Microtech LT8s with upgraded MAP sensor to 5bar
Boosting 2.7 bar peak and taper to 2.5bar hold
Sparco Pro 2000 buckets
Sparco deep dish steering with boss kit
Fully lightened interior
Defi amber oil press, oil temp, fuel press & boost
Defi CUII
Pivot Shift Lamp
Pivot Blue VS
Custom 3" straight through exhaust system
Jasma Exhaust rear
Project miu 800 deg brake pads
Brembo slotted rotors 335mm
17" Stock rims sprayed gold
R888 semi slicks
Varis CF bonnet
V Lip & sideskirts
Rear diffuser
Bumper diffuser
Full ARP studs and bolts
O-100kmh in 2 secs flat & 1/4 mile 10 secs approx 9.98 secs
ek9
Post by ek9 »
2 seconds :) there must be some sort of typo here.... Mclaren p1 does 0-100 in 2.8s btw ^.^
xiaohong
Post by xiaohong »
Nope.. it was clocked. Was shocked but i cant stop the disbelife
xiaohong
Post by xiaohong »
Btw to add i missed out. I was boosting 2.7bar
zeepo
In: Pewter Grey
Post by zeepo »
this guy is crazy!
Tymondo
Options: R - APR Stage 2+, Milltek cat back no resonated, Peron Intercooler, Forge hoses, Anti-Lift Kit, RS4 FPRV, VWR Induction, VWR Springs, GFB DV+, NGK Iridium plugs. Cup Spoiler and Maxton Splitter, Side skirts and diffuser.
GT TDI - Now sold
Post by Tymondo »
Some nice lunchtime reading :nod:
Scirocco R Build thread -> http://www.sciroccocentral.co.uk/forum/ ... 13&t=23485" onclick="window.open(this.href);return false;
KennyLam
In: Salsa Red
Post by KennyLam »
Your Rocco is really nice, thanks for sharing.
edbertelika10
Post by edbertelika10 »
hey , what is the brand of your carbon shifter?
xiaohong
Post by xiaohong »
edbertelika10 wrote:hey , what is the brand of your carbon shifter?
Got it off ebay :)
xiaohong
Post by xiaohong »
Tymondo wrote:Some nice lunchtime reading :nod:
Thanks for the compliments :)
xiaohong
Post by xiaohong »
KennyLam wrote:Your Rocco is really nice, thanks for sharing.
Thanks for the compliments dude :)
roccolove
Post by roccolove »
hey, you have a really nice car thanks for sharing and congrats on making it so perfect.
I have a few questions in my ming, as I see you're driving a dsg box. Is that effected you ? What is the cont and peak turbo bar amounts you use right now ? Do you have any dsg upgrade kits for your car rather than the dsg software upgrades also you can use launch control I guess.
I have a remapped 1.4tsi, we have an aggresive remap with 1.9 peak and 1.7 continous bar on stock turbo. Now I am planning to go for hybrid k03, I dont plan to change/increase piston rods etc. but I will change valve springs and engine upper lid(sorry I dont know how to translate it exactly :( )
actually I dont have many knowledge about the turbo and engine and I dont see many people doing such work on 1.4tsi 160hp, for example what kind of an exhaust do you use ? Do I need to change my downpipe after hybrid upgrade ? will my forge dumpvalve still be functioning ?
I know I have written many things but I'll be very happy to find out :)
xiaohong
Post by xiaohong »
roccolove wrote:hey, you have a really nice car thanks for sharing and congrats on making it so perfect.
Hi!
answers to your questions:
peak 1.7 tapers to 1.55 hold
DSG box for the 7speed is holding well so far. No clutch upgrades
Valve springs help holds boost solidly and maybe you might wanna try porting :)
changing a dp would be recommended even just with a stage 2 tune for better flow if you have either esienmann supersprint remus etc quads
For the forge dump valve, its a spring controlled device and I would prefer the stock DV as there is a new revision for it by VAG. Makes the tuner's job easier too :)
post your dyno sheet for us to see and drool!
cheers
Babajang
In: Indium Grey
Post by Babajang »
wow, serious work going into this scirocco! i like it! :) keep up the good work man.
xiaohong
Post by xiaohong »
Babajang wrote:wow, serious work going into this scirocco! i like it! :) keep up the good work man.
