Servicing
RW1
Legend
Hi from Sunny Stopfordia
Re: Servicing
Post by RW1 »
For the oil filter I took your engine code to be a 'CBD' 140PS diesel. If its a later 'CFH' 140PS diesel, then it will be 03L 115 562. (On your boot sticker or service log book inside page.)
29 Oct'09 at dealers
Driving 4th Nov. Sorted!
lugano
Re: Servicing
Post by lugano »
One final question i hope, is the sump plug instantly accessible from underneath the car or are there likely to be any plastic covers/baffles to take off first to get access to the sump plug? :)
RW1
Legend
Re: Servicing
Post by RW1 »
There are two types depending on factory build. A quick look under the Scirocco from behind the rear of the front right tyre will tell. In the middle of the car the sump bolt will be visible or the full undertray cover will be in place. Not hard to remove with the car raised a little. Remove the Torx Bolts and it slides slightly backwards and drops out.
This is the open version with a big "moon" cut. So the sump bolt is easily accessed.
The Bluemotion usually is filled in where the engine and gearbox representations are shown in the first photo. Has 3 extra Torx bolts on the rear lip edge.
lugano
Re: Servicing
Post by lugano »
Excellent images, it had the torx screws which i removed to detach the under cover baffle & saw the 19mm sump bolt. Its all done now, thanks fella you know your stuff :clap:
louisanderson68
Re: Servicing
Post by louisanderson68 »
Great post, just what I needed, I'm attempting a manual oil change this evening.
